Connecting e-brake cable
Old Sep 22, 2009 | 03:56 PM
Dick72LT1's Avatar
Dick72LT1
Default Connecting e-brake cable
Jeez, I feel stupid again. I just installed new Delco calipers on the rear of my car. I figured the e-brake cable would be the last thing to install. Guess I was wrong. I can't get the cable to 'snap' into the e-brake actuator arm on the wheel. Is there a trick or do I have to take it all apart and snap the cable into the lever BEFORE I install the calipers? I've tried all kind of long thin tools working through the space where the inner pad goes.
Can you guys help me out again?
Thanks for all the help in the past.
Dick
Old Sep 22, 2009 | 05:14 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Install the cable 1st. You'll be fighting it all day if you don't.
Old Sep 22, 2009 | 05:21 PM
...Roger...'s Avatar
...Roger...
I think I understand what your saying. You should be able to take the adjuster nut off and get enough slack to get both ends in place (as VS said), then put the adjusting nut back on.
To Connecting e-brake cable
