Which jets
Old Sep 24, 2009 | 07:11 PM
painterman52's Avatar
painterman52
Default Which jets
I replaced my 670 street avenger with a 650 double pumper with mechanical secondaries. I dynoed the car with the 670, the jets were 68 & 70. Should I have the same with the 650?
Old Sep 24, 2009 | 08:24 PM
midyearvette's Avatar
midyearvette
no..they are metered differently, surprisingly you may want to richen the dp or at least give it a try...on the other hand, the street avengers are jetted too lean out if the box....good luck
Old Sep 25, 2009 | 09:20 AM
Matt Gruber's Avatar
Matt Gruber
no,
what model 650?
does it have 2 power valves?
Old Sep 25, 2009 | 04:12 PM
painterman52
#4777. Yes it has 2 power valves. They are 6.5. I have about 13 inches of vacuum at idle. I have performer rpm heads and a lunati flat tappet cam 227/233 @ .50 110 lsa.
Old Sep 25, 2009 | 04:26 PM
Matt Gruber
71 & 76 is what my book says, stock.
that is race carb that series is infamous for running rich out of the box. All 5 circuits will need tuning for proper street use.
Good for the drags & dyno if that is your hobby.
what intake do u have?
Old Sep 25, 2009 | 05:29 PM
painterman52
Performer rpm intake. there are a number of different models for the 4777 I think. I have 67/73 jets. I`m not positive about 2 power valves.
Old Sep 25, 2009 | 05:55 PM
Matt Gruber
if u r happy with the way it runs, no black smoke, go get a dyno test.
if u or anybody else with a gas sucking drag car want to convert it to a 17-19 mpg cruiser with NO LOSS OF POWER at the track, there are several ways to do that with a double pumper made for the street.
My favorite combo for u:
4165 holley DP 650cfm
performer RPM Q-jet #7104
base gasket 108-21
To Which jets
