carb sizing help
Old Sep 27, 2009 | 04:53 PM
ekess744's Avatar
ekess744
Default carb sizing help
I was given a holley 600 dp that needs a rebuild for my motor. I am wondering if it will be enough...
383
edelbrock torker 2 single plane
ported 113's with 2.00 valve
230/230 cam with .560 lift
Old Sep 27, 2009 | 05:04 PM
baxsom's Avatar
baxsom
auto or manual.
normally the auto cars should get a vacuum secondary.
size should be fine.
Old Sep 27, 2009 | 05:49 PM
ekess744's Avatar
ekess744
manual 3.07. It's a lightened c4 weighing about 3000lbs
Old Sep 27, 2009 | 06:05 PM
Matt Gruber's Avatar
Matt Gruber
what is the list # on the air horn?
Old Sep 27, 2009 | 06:12 PM
hdpete98's Avatar
hdpete98
General rule of thumb is:
(max RPM's x Cubic Inches) / 3480 = cfm
For your application:
(6000 x 383) / 3480 = 660 cfm
Would not go smaller than 650 cfm carb
Old Sep 27, 2009 | 06:13 PM
ekess744's Avatar
ekess744
list-4776-2
Old Sep 27, 2009 | 06:14 PM
hdpete98's Avatar
hdpete98
I forgot, always vacumn secondaries with an auto trans.
Old Sep 27, 2009 | 06:15 PM
ekess744's Avatar
ekess744
I was hoping because its a mechanical secondary that I could get away with it for atleast the break in, but if its too small, it's too small.
I was also hoping because it was free
Old Sep 27, 2009 | 06:20 PM
hdpete98's Avatar
hdpete98
I just put a 2-plane edelbrock and a holley 650cfm, with vacumn secondaries on my 71 350/auto with a mild cam, no headers. this carb works great but it doesn't have much left at wot. With your 383/auto, I don't think you would be very happy with the the 600. By the time you have it rebuilt the difference in cost would be well worth it. I would look at a 750 but nothing smaller than 650 cfm.
Good luck.
Old Sep 27, 2009 | 06:22 PM
ekess744's Avatar
ekess744
its not an auto
Old Sep 27, 2009 | 06:32 PM
Matt Gruber
size looks very good! with a single plane all 8 cyl use the entire carb.
Most guys use a dual plane, each half of the carb feeds 4 cyl, then it is iffy.
if u put a kit in it yourself, try it!
Old Sep 27, 2009 | 06:33 PM
ekess744's Avatar
ekess744
I haven't opened the kit yet which is why I am debating
Old Sep 27, 2009 | 06:56 PM
Matt Gruber
take the bowls off, etc., is it clean or full of dried gas? if it looks ok, get a spray can of carb cleaner and blow thru every passage.
If for some reason u decide to sell it, it will fetch much more rebuilt, like 75-$100
I don't think it is the best carb, but it could run a lot better than many, so the price is right, try it!
Old Sep 27, 2009 | 07:13 PM
Ganey's Avatar
Ganey
It will work w/ your single plane intake.
AFR put a 600 DP on a dual plane 383. You can get a larger carb later.
Old Sep 27, 2009 | 08:22 PM
CFD E59's Avatar
CFD E59
Hummm............
Old Sep 27, 2009 | 08:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Trying to put this in a nice way but every time I see that formula I cringe. Would you use a the same size carb on a 300HP 383ci that you would use on a 550HP 383ci. ?
Seriously not trying to start anything or make anyone feel bad but that formula comes up all the time ( whatever math class it came from ) and it just makes me feel I have to say something to clear thngs up. Putting anything smaller than 750cfm (Holley square bore type ) on healthy 383ci is nonsense.
The 650cfm is good for a slightly warmed over 355ci although I had a Holley 750DP mechanical secondaries on my warmed over 355ci which made ~300RWHP and 330RWT and had very nice street manners with a single plane Vr Jr intake manifold and solid fllat tappet cam
Old Sep 27, 2009 | 09:42 PM
midyearvette's Avatar
midyearvette
especially about that dumb azz formula on any kind of performance engine jmo
To carb sizing help
Old Sep 28, 2009 | 12:15 AM
ekess744's Avatar
ekess744
I decided to buy a Holley 750 vacuum secondary carb. 3310 with electric choke
Old Sep 28, 2009 | 05:59 AM
baxsom's Avatar
baxsom
you are assuming 100% efficiency from this forumla.
no NA engine will give that. maybe close but not quite.
if it is a well tuned, efficient, large valve engine that say was giving 90% of what it was capable of the 600 would be perfect
660*.9=594cfm
if you already have the carb and it is a manual. go for it.
Old Sep 28, 2009 | 06:51 AM
Matt Gruber
that is not a step up imo. i'd sell that ASAP. But,that's me; others love VS.
the 113's are ported to what? they are only 163 cc stock. about the worst head for a 383. flowing 600cfm at 1.5 is unlikely, more like 550.
a 600 DP will flow 780 cfm at 3" of vacuum.
i'd rather have the 600 DP any day on this combo
