Not so common starter ?
Old Sep 28, 2009 | 07:18 PM
Neptune75's Avatar
Neptune75
Default Not so common starter ?
i have finaly got my 496 bb running!!! when i started the car for the fourth or fith time i noticed a awful grinding noise i figured it was the starter was to close to the fly wheel and i would shim it to correct the problem. this is a ac delco starter brand new. when i got underneth the car i noticed that the starter was to far out. the pinion shaft was about 3/8" to far away im getting about 10% engagement.. i was wondering if any one has ever milled there starter to bring it closer to the flywheel???? oh by the whay its a automatic with a 168tooth.. moter head, gkull i expect to se a good response! lol
Old Oct 1, 2009 | 07:28 PM
Neptune75's Avatar
Neptune75
ok i took it to a machine shop and they are goin to mill it down i let you guys know how it goes.
Old Oct 2, 2009 | 08:23 PM
Ironcross's Avatar
Ironcross
You should be using a 'cast iron' nose starter...I think you have the wrong one. Never is it required to cut the nose of any starter. I suspect the one you have is aluminum which would not be correct.
Old Oct 3, 2009 | 10:20 AM
Neptune75's Avatar
Neptune75
im not cutting the nose off.. i am simply milling the mounting surface to bring starter closer to the flywheel..
Old Oct 3, 2009 | 10:22 AM
Neptune75's Avatar
Neptune75
taylor michigan.... is that close to Flint Mi??
Old Oct 3, 2009 | 04:23 PM
Ironcross's Avatar
Ironcross
No, West of Detroit along I-94 near the Metro airport..
Old Oct 3, 2009 | 05:41 PM
Neptune75's Avatar
Neptune75
i work in warren at the gm tech center in the research and development building ..engine dyno department
To Not so common starter ?
