driver side dash install 68 vert
Old Sep 28, 2009 | 08:56 PM
base1957's Avatar
base1957
Default driver side dash install 68 vert
Are the speedometer and tach cables routed under or above the wire harness?
Old Sep 29, 2009 | 08:21 AM
base1957's Avatar
base1957
ttt
Old Sep 29, 2009 | 02:01 PM
DZRick's Avatar
DZRick
You should really purchase an AIM, it's well worth the money and you'll find alot of your answers in it.
These should help.
Here I'm pointing to the harness.
And in this one I'm pointing out where the speedo cable attaches.
Old Sep 29, 2009 | 06:13 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
its a frigging nitemare trying to stuff everything back there,
and not dissconnect something else !
be very careful of the sharp edges on the column mount it is rough casting,
and can cut into wires, I split some rubber hose and covered the sharp edges to avoid a short/Fire ! ... good luck ! 69VETT
Old Sep 29, 2009 | 11:08 PM
base1957's Avatar
base1957
rick
ive got one. i knew where it hooked up but wondered how to route it so that putting the dash back would go smoother. I disconnected them and the dash went in easy.
thanks
Old Sep 30, 2009 | 10:18 AM
DZRick's Avatar
DZRick
Originally Posted by base1957
rick
thanks
I know that is one of the tougher parts to install, glad you got it done.
To driver side dash install 68 vert
