Lead Additive 1970 LT-1
) Read the posts digest the information try to see what is good and what is hearsay, good luck with your Vette, LT-1's are my favorite C3 Vette, I like them so much, that I own 2, one to win shows and another to win races with and both get lead additive and high ZDDP oil packagesBack in the late 80's and early 90's I worked in a machine shop where I did all the head work. I saw maybe half a dozen heads come in with sunken valves. Every one of them were from trucks which were lugging the motors down pulling heavy loads. Never saw this happen on any kind of performance engine. Never.
I am guessing you fall under this catagory of user in Chevrons terms: Vintage Vehicles:
Antique cars are typically exposed to such light service that they are not expected to have any valve seat problems. In fact, they stand to benefit overall from a reduction in exhaust system corrosion and oil contamination.
Your Vette is probably an "Antique" a LT-1/L-89/L-71/L-88/LS-6 Corvette being as how they are true performance cars are HIGH SPEED engines hence the 6500RPM red line on their tachometers. Hope this clears up your IGNORANCE of performance Corvettes, they don't have oil pressure problems causing them to make the clattering noises at idle, they have SOLID FREEKING LIFTERS making them HIGH RPM performance machines!
Just as I thought- somebody with no practical experience playing the part of an internet guru.
Thanks for the link to the Chevron site- that makes my point perfectly:
"The problem can only occur in older engines when operating under sustained high speeds and loads."
The keys are sustained speed and loads. A Corvette does one or the other, but not both on a sustained basis. A quick trip up through the gears does involve high (engine) speed but it is not sustained. A Corvette cruising at high revs does not constitute a high load.
Please go back into your cave until you can learn to stop spouting personal insults. Thanks.
[/B]
I have a milder hydraulic lifter engine (LS5) that I mostly use just to tool around town and let her pull hard when the opportunity presents itself, and I sleep just fine at night without spending any money on lead additives. I do spend money on high quality synthetic oil, but that is more about wanting the oil to last in the crankcase for a full year without breaking down than it is about fretting over zinc and phosphorous content.
Besides, I have good use for the money I save by not buying lead additive, it looks like this:
Sorry PK, but that just lends credibility to a myth and exposes owners to another possibility. Some heads have been ruined through modification for hardened valve seats by accidental machining into the coolant passages. Others have had the valve seat fall out during operation, particularly at high rpm. Obviously this would damage much more than just the head and valve.
Like many owners I panicked when unleaded gas first appeared and refused to use it in any of my toys (most of which I still own). As years went by and more real-world experience appeared, it became obvious that the sky was not falling. The only actual case I know of is with a buddy who owns a pair of TR6s, one a '71 and the other a '74. Both appear to have suffered accelerated valve seat erosion after finally switching to unleaded gas but there again British cars of that vintage were not exactly models of high reliability and long durability.
Similarly, I have never read anything to support the idea that the milder hydraulic lifter engines need exotic oil additives to prevent damage to the cam lobes. Clearly, using a high quality oil with appropiate additives can be shown to increase engine life when compared to the blue light special oil at K-mart, but I am unconvinced that someone who has, say, a 1976 L-48 needs to run around worried about the ppm of zinc in his oil to prevent premature cam wear. If you have information to the contrary at your fingertips, I would be very interested to read it.
I think a lot of what I am getting at here is that when one sets out to design a truly performance engine, and leaves behind things like hydraulic lifters and lower compression, moving on to higher compression and solid lifters brings along with it higher maintenance (like adjusting valves) and potential problems (like the higher probability of wiping a cam lobe). But somehow, it seems that some of the cautionary tales that are appropriately applied to these engines get caught up in the "Corvette lore" if you will, and get applied to engines when they shouldn't. L-48/LS-5, these are street engines designed for reliability and relatively low maintenance. That doesn't mean I can't wipe a cam lobe tonight on my way to the local cruise-in, as I certainly can, but I can also wipe a lobe on my Exploder driving to Home Depot for a box of nails.
The bottom line is, there are millions of flat-tappet vehicles out there. If the 800 ppm ZDDP level was going to round out the lobes of the cams of these cars and trucks inside of 300 miles or 900 miles, or whatever number of miles the scare-tactic article you last read stated, the public uproar over the change to the oil would be deafening. In reality, even a guy who likes cars like me has to pretty much go looking for information on this, so IMO, the hullaballoo is clearly overblown.
Again, I am a believer in high quality synthetic oils for a variety of reasons, I just don't lose sleep over the ppm of zinc in my oil.
BTW: IMO, STP is a crock. Just as bad as the "octane booster" in a little plastic bottle. Just snake oil to take your money.
Oh, and in case anyone was wondering: a "VGS20" is a Sunnen Valve Guide and Seal machine. I didn't know what any of the other stuff in Solid LT1's posts was, but a quick Google search led me to believe that a "SF901" is a dynomometer. I'm not sure how the mention of that stuff was supposed to impress anyone. Just let it be known that you guys don't have any idea who you are messing with either, because in real life, I am 6' 10" tall, weigh 340 pounds and can bench press a Chevelle 8 or 10 times, depending on how I am feeling that day. Just keep that in mind if it was me that was referred to as a "hoser".
I am the first to admit I know little to nothing about these and most of the other topics I started, which is why I started them.
I owned a 2004 C5 and wanted something different, I knew the 70 LT-1 would require some more maintenance but I was obviously unprepared to the degree of maintenance.
I put Castro GTX High Mileage 10w-30 into my car. Now I here it does not have the proper ZDDP ratings, what am I to do? Is 10w-30 even correct for my car? I live in San Diego.
California only has 91, does this matter? How can I tell if the car is pinging or knocking?
Finally the lead issue, at the very least the 6 dollar bottle of CD2 lead additive is cheap, and lasts for 160 gallons, I figure if it does not hurt I will do it.
By the way, Tyson hit harder the Norris, but Norris had more heart.
about camshaft wear.Once again, maybe I am not being clear enough. I am talking about street engines here, AND hydraulic lifters. I have read the scare articles about 200,000 psi pressures between the lifter and the lobe, and the engineering side of my brain says "huh? How could that even happen with hydraulic lifters and my oil at 60 psi?" Maybe I have an insufficient understanding of the problem, but it all smells like
However, for the removal of doubt, if I had an original mechanical lifter engine in my car, I would buy the best oil available for it.
but to each his own.
For what it's worth I use the Amsoil oil that Mako mentioned- right, wrong, or indifferent!
I'm not as big as you guys, so excuse me while I go kick the dog.
Now Syntec is a full synthetic, how would I go about switching from Dino to Synthetic?
Also as far as the pinging/knocking, unfortunately/fortunately I am only 25 (26 tomorrow), so I have never been in an old car besides my own (which I got a couple weeks ago) and my friends 65 Chevelle which is in really good condition.
http://www.valvoline.com/faqs/motor-oil/racing-oil/76
this is what i use
http://www.valvoline.com/pdf/VR-1_Racing_Motor_Oil.pdf
Being called a 'hoser' would make any Canadian laugh. The term comes from a skit performed by the McKenzie brothers on SCTV in the early 80s.
The humour within the humour is that most of the jokes were made up just to mock the stereotypes bestowed upon us by our neighbours to the south. I've never once heard a Canadian actually say 'hoser' or 'take off, eh', so the joke worked quite well in this case.
You don't need the leaded gasoline.
