Ok....I have a 454(1974 by the engine code) in my 68. I have a loud knock when the car is at idle(not a valve tap, a knock) It seems to go away when I give it some gas while driving(engine is under load) and only if I'm rolling, (the knock is there if I'm just revving in neutral). As soon as I get off the throttle, it comes back. I know what ever it is isn't good, just wondering where to start looking first.
Could be carbon knock from a peice of carbon on a piston. How many miles on the motor , is it stock compression and what octane do you use?
Back in the 70's I had an old Ford pickup that did the same. I rebuilt the engine and found it was the timing chain slapping at idle. The chain was so stretched I can't believe it didn't jump teeth.
Get an engine stethoscope. They are fairly cheap and indispensable if you have engine noises. You might be able to hear it and find the locale of the sound. Sounds a little like a rod bearing or wrist pin to me. Under load the chambers have a lot of positive pressure holding the rods tight to the crankshaft. On deceleration or idle they are a little "loose" on the shaft and you will typically hear a loud knock.
Here's a little info:
Listen with your stethoscope. A rod bearing makes more noise at the oil pan than elsewhere, and a wrist pin more racket up on the water jacket. Hold RPMs at 2500, jerk the throttle open and let it snap closed. This will accentuate rod knock, whereas pin noise won't change very much.
Start shorting out cylinders. A bad pin will quiet down, but a rod knock will double its cadence. (This is due to no power on compression stroke because the plug is is not firing)
Pull the pan for a visual inspection. (Check for metal in the oil. Bad bearings make the oil look kind of like metalflake paint ) If the bearings are good, you know you've got a pin problem.
Lots of things to check but sounds like a thrust bearing issue to me.
I have a feeling it's a rod or wrist pin. It's a loud knock, not an octane or detonation kind of knock. I have a stethoscope, but haven't been able to really narrow it down. I will definitely use your suggestions Highschool...great info. I'm hoping for wrist pin(could still drive it now and then till winter hits) I plan on a complete tear down over winter anyway.
I had a 460 (I know ) in a boat that had piston slap at idle for over five years without incident. Older marine mechanic told me it was "normal for that engine". Drove me crazy for the whole five years! Sounds exactly as described, only at idle; and ran super strong.
