Ken Harrison KHE 300 Stereo
Old Sep 30, 2009 | 06:22 PM
base1957's Avatar
base1957
Default Ken Harrison KHE 300 Stereo
Got the stereo in and wondering. How does one utilize the RCA jack in the rear.
I want
1. 2 front speakers
2. 2 Rear speakers
3. Sub: Self Powered or not
thanks'
Old Sep 30, 2009 | 06:48 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I want
1. 2 front speakers
2. 2 Rear speakers
thanks'
The RCA's output =low voltage. This signal requires a separate amp or powered speaker/sub. I would use the front and rear speaker out on the radio for your main F/R speakers and then, cable the left side RCA to a powered sub if you want a sub.
BTW, not wanting to rain on your party, but I have a KHE 200 and I am not impressed! the multi-function potentiometer is junk and shorts the balance and tone circuits anytime I touch the ****. POS! Next time the dash come out it's gone!
Ganey's Avatar
Ganey
RCA jacks are used to connect amp(s). Do you have 2 or 4 RCA jacks?
Old Sep 30, 2009 | 06:53 PM
base1957's Avatar
base1957
on the back there are two rca jacks
1. is for the cd input
2. is a set that says "line out"
Old Sep 30, 2009 | 07:01 PM
base1957's Avatar
base1957
Default Pic posted
ONE ON THE LEFT IS FOR CD / AUX INPUT
ONE ON THE RIGHT IS FOR LINE OUT
Old Sep 30, 2009 | 07:16 PM
Ganey's Avatar
Ganey
1 set of line out is for 1 amp. What are your plans for front & rear speakers i.e. what sizes & where? Some speakers do not need a sub.
Old Sep 30, 2009 | 07:22 PM
base1957's Avatar
base1957
i have no particular brand in mind but prefer good sound not a 29.99 speaker. dont mind paying a few bucks.
will two (best i can find that will direct fit) in lower kick panel area
will put two 6 x 9 in the rear compartment
68 vert
Old Sep 30, 2009 | 08:28 PM
Ganey's Avatar
Ganey
There are 4x6 plate speakers w/ mid. & tweeter. Some 5.25 can be fitted to kick panel location behind factory panels. A mounting plate should be used to separate the front from back sound waves to prevent cancellation for better bass.
If you are going to run a sub, then consider something like 5.25-6.5 in back instead of 6x9.
PS I have removable rear speakers eq. to 2 8's & no sub (not needed).
http://forums.corvetteforum.com/showthread.php?t=634468
Old Sep 30, 2009 | 09:52 PM
base1957's Avatar
base1957
Will look at the smaller ones in the rear as you suggested. Should I just wire the two front and rear speakers through the speaker wiring from the head unit and then run the sub through the rca jack?
Does the RCA jack divert all of the sound through the sub or better question is what signal travels through that rca jack out
Old Oct 1, 2009 | 07:30 AM
Ganey's Avatar
Ganey
Yes, you could run the speakers from the head unit & an amped sub. as the low freq. take more power.
A stereo has a preamp. that raises the signal level enough to send to an amp. so the RCA outs are a connection to preamp. sometimes called line out. So it's a connection & does not divert all the sound.
Some amps. have speaker level inputs.
Component speakers are rec. for best sound- no coaxials or ovals.
To Ken Harrison KHE 300 Stereo
