Holley 3310-1
Old Oct 2, 2009 | 06:40 PM
1971 LS-5's Avatar
1971 LS-5
Default Holley 3310-1
Can someone tell me please what power valves are appropriate for this carb? As some of you may know, this carb has 2 power valves, one in the primary metering block and one in the secondary block. I read some where the stock configuration was (72 front jets 10.5 PV, 76 rear jets 8.5 PV). It would seem like a bad idea to have the secondary power valve open before the secondaries do. The proper way to size the front power valve is to take a vacuum reading and cut it in half (12" vacuum = 6.5 PV). But there is no such explanation for sizing the rear power valve that I know of. Anybody got any ideas?
Old Oct 2, 2009 | 06:56 PM
LT1driver's Avatar
LT1driver
if nobody responds check out the how to rebuild holley books.
Old Oct 2, 2009 | 07:28 PM
midyearvette's Avatar
midyearvette
10.5 primary and a 8.5 secondary power valves were used in your model carb......the reason some holleys had a secondary pv is due to fuel economy and to provide some high performance characteristics for the street, hence the earlier opening primary valve....this carb has always been a bear to tune in applications where a long duration camshaft is changed from a mild factory high performance camshaft...if you use the rule of half manifold vacuum to select your pv, you may find a flat spot at cruise because this model is jetted a little lean for the 10.5 pv....by the same token, if you remove the rear pv and plug it you then should richen up the rear jets by at least 3 numbers...try to use it as stock as it was intended ....then just richen up the primarys if need be, however unless you are pulling over 11 inches of vacuum at idle, the 10.5 pv will cause problems, if you go to say a 6.5 pv in the front then you must jet up (richer)..hope this helps, like i say that particular carb is made for a very mild street mill and trys to give some economy in the process......good luck.....
Old Oct 2, 2009 | 09:24 PM
midyearvette
Originally Posted by Little Mouse
3310-1 is a 780 vacuum secondary carb with no rear metering block it has a metering plate the front power valve is a 6.5 or part number 125-65 for the power valve.
nope....for sure has a metering block and jets and a power valve in the secondary....holley manual # 3310-1....
Old Oct 2, 2009 | 10:00 PM
Little Mouse's Avatar
Little Mouse
maybe its an R83310-1
does not matter both came with 72 primary and a 6.5 pri. power valve.
Old Oct 2, 2009 | 10:12 PM
GDaina's Avatar
GDaina
Guys, the early 3310 had the metering block, the later 3310 had the plates...so the carb came in both flavors.
Old Oct 2, 2009 | 10:21 PM
midyearvette
nope..10.5 power valve primary and 6.5 secondary....weird huh??...
Old Oct 2, 2009 | 11:12 PM
1971 LS-5's Avatar
1971 LS-5
I'm with you midyear, anytime the 3310-1 is brought up in conversation it confuses the crap out of people. It is not an ordinary 3310, 4160, 750cfm carb. By the way, my motor is a basically stock LS-5 with headers and exhaust. What attracted me to by this carb was its originality. It has the #'s correct metering blocks and was jetted 72,76. I have never seen the type of power valves it had though. They are stamped on the side, in the flats were you unscrew it instead of on the metal in front of the diaphragm. One is stamped 105 (10.5 I assume) and has small holes instead of a window. The other is stamped 2 and has small windows. I'm fighting this carb loading up and I'm considering putting these power valves back in. The diaphragms look good and they have good movement. They should be good right?
Old Oct 2, 2009 | 11:16 PM
GDaina's Avatar
GDaina
suck on the diaphragm and if it holds the valve is good if not pitch it...by the way, I have a can full of power valves and every one is stamped on the side
Old Oct 2, 2009 | 11:27 PM
midyearvette
yep..another way is before you tear the carb apart, screw in the idle adjustments closed, if it still runs, the front pv is blown, tough to do on the rear though.... btw the rear pv only works along with the vac secondaries when they are partially open....
Old Oct 3, 2009 | 12:00 AM
Little Mouse
both carbs come with a 6.5 power valve in the primary.
Old Oct 3, 2009 | 12:21 AM
midyearvette
little mouse.....i am quoting holleys numerical component parts listing for the 3310-1 model 4150 780 cfm.... re build kit #37-1084...this kit is exclusive to that 780 carb because it contains the two proper pv's ...a 10.5 for the front and an 8.5 for the rear.....the bigger valve is used in the front for early power enrichment (higher vacuum) because that model is metered on the lean side....they tried to make this an economy oriented carb and it falls short on some mills....the pv in the rear is a neat idea because it allows leaner jetting in the rear which is actually a part of the idle circuit too...it needs less fuel at an idle, trying to achieve even more economy, kind of contradictory of a performance carb....
Old Oct 3, 2009 | 12:35 AM
Little Mouse
The holley book for the carb both the 3310-1 (4150) and the R83310-1 (4160) from the ( Factory Carb ) not a rebuild kit shows a 6.5 power valve for the carb 72 primary jets for both carbs.
Now I can only go with the carbs I have had apart or what the holley book says ( assuming no misprints or screwups )
To the OP unless you have extreme good idle vacuum hauling
a heavy trailer with the vette lol. I suggest you use a 6.5
if need be richen the primary jets up from the 72s if you have a very big cam very low idle vacuum then you will need something lower then a 6.5.
So lets see you stick in some reall small jets then try to fix it under
load with an earlier opening 10.5 fuel enrichment valve.
Old Oct 3, 2009 | 12:37 AM
GDaina's Avatar
GDaina
3310 A and 3310 1A primary 10.5 secondary 8.5
3310 2a primary 10.5 secondary plate
The above per Holley Illustrated Parts and specs and initially this carb was used on the 396 425 hp Corvette
Mouse, reason you've seen 6.5 inch valves, is that guys ditched the 10.5 and put 6.5 inchers...I've purchased countless of 3310's from swap meets and almost everyone had 6.5 inchers, some had 8.5's but I never eveer came accross a 3310 with 10.5 in the primary
Old Oct 3, 2009 | 01:45 AM
Little Mouse
[QUOTE=GDaina;1571697542]3310 A and 3310 1A primary 10.5 secondary 8.5
Ok the 3310-1 does have a 10.5 valve MY BAD.
All my carbs were metering plate 4160s they have the 6.5.
why would you need a 10.5 power valve even the jets are the same
72s as the 4160.
you have a light weight car 427/425 hp, solid cam probably
13 inches of vacuum a 10.5 power valve, insane.
I see the later 750s all have a 6.5 power valve that makes sense.
To Holley 3310-1
