I rebuilt a Holley Carb, Probably didn't do a good job. Seems to be dripping gas rather than a fine mist. It doesn't idle well. I've plugged all the Vacuum hose to see if it was a leak.
The cam in the car is a solid lifter flat tappet, pretty big I assume since I only get like 5in of vacuum.
The power valve I used came with the rebuild kit, but I think I need a different one because of my cam any one else agree?
Well if you are only making 5 " of vac, check to see that you have a 2.5 power valve in it. What does is make for vac in gear? You need to be 2 sizes smaller on the power valve than the vac reading in drive.
At what rpm point is it dripping gas? If you're witnessing this at idle and it's coming from your boosters, then your fuel level in the bowls is too high. If it's at higher engine speed, it could be any number of ills in your main emulsion well, but this would be pretty hard to see while eyeballing the boosters since the main circuit has to be flowing. This would be a fuel shear issue. Outside of more detail, I'd have to guess it's an idle and fuel level issue since the boosters don't have enough velocity to shear fuel and this is when you'll get the big drops instead of the atomized delivery.
If this is at idle, it won't be in your power valve since this circuit flows fuel only when the boosters are flowing and it would be the same fuel shear problem.
At Idle I see the dripping, I've adjusted the level in the bowl as best I can, the car is on my driveway with a slight incline.
Try harder. The only cause of fuel coming out of the boosters at idle is the fuel level in the bowls is too high. It could be the floats are set too high, bad needle and seat, fuel pressure too high, or a faulty float.
It's a common misconception that the power valve has any affect on the idle mixture - it affects the mixture only when the main circuit is started, and then its effect is to provide a enrichment when the vacuum drops below its nominal value. At idle, there should be NO fuel coming from the boosters.
all true gerry, u know your stuff
But with this big cam, and 5", he may of turned the idle screw speed in so far that he is idling on the main booster unlikely, true, but you never know until u look
will the power valve come into play at Idle in this case? Sounds like I must adjust the fuel level first then how important is it to have the right power valve?
No. not unless u turned the idle speed screw as far as it will go.
switch f & r needle. if rear floods, there is dirt on needle.
PV is important, but not today. 1st set fuel level, stop drip.
