Wheel spacers?
Old Oct 7, 2009 | 01:22 PM
99blkvert's Avatar
99blkvert
Default Wheel spacers?
Any body know where I can get some spacers for my 73? I only need them for the front. Any help with this is greatly appreciated. Thanks,
Justin
Old Oct 7, 2009 | 01:35 PM
toddalin's Avatar
toddalin
Justin
Summit Racing has a variety.
Old Oct 7, 2009 | 04:53 PM
FKING1's Avatar
FKING1
Old Oct 7, 2009 | 07:13 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Just be CAREFUL!!!!! If using a wheel spacer...you better change out the wheel studs to the longer design...due to the wheel spacer will "possibly" cause the amount of thread to be decreased...thus not allowing your lug nuts to have enough threads to properly secure your wheel to the car.
IT'S YOUR LIFE.....and the woman with her kids in the oncoming lane.
If using an original lug nut with the threaded hole going through it....make sure that you have AT LEAST TWO threads EXPOSED past the nut when tightened. IF using a lug nut that does not have that ability to see the threads coming through it...you better make sure that you have the same amount of threads...if not more threads coming out of the wheel...after the spacer is installed as like it was before you installed the spacer with the factory set-up.
"DUB"
Old Oct 8, 2009 | 05:43 PM
FKING1's Avatar
FKING1
Can use a 1/4" spacer without a stud thread problem. Have them on my rears. As said above if no threads showing above the nut, get longer studs.
Old Oct 11, 2009 | 08:57 AM
surfertom's Avatar
surfertom
send me your address and i'll send you the 2 i'm not gonna use. they are 1/4". put the tourqe thrust d's on my cutlass and got different wheels for my 69 coupe. tom
Old Oct 11, 2009 | 09:21 AM
MN80Vette's Avatar
MN80Vette
Default How long are the stock studs?
I checked Summit and they have 136 different sets of studs. Correct me if I am wrong: The stock studs are press-in and 7/16-20.
Summit has some with a .560 knurl or .480 knurl. Which size would I need?
Is there anything else to consider when choosing studs?
To Wheel spacers?
