Saginaw ID help, please.
Old Oct 7, 2009 | 07:36 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Saginaw ID help, please.
The transmission case numbers are GM 392 5658. It has a 3 ring spline.
Anyone have or know where I can get info on this (year, what it might have come out of, etc.)?
TIA
Old Oct 8, 2009 | 05:56 PM
Avette4me's Avatar
Avette4me
I'll take that as a no ...
Old Oct 8, 2009 | 06:09 PM
Duke94's Avatar
Duke94
My "Corvette by the Numbers" book shows 3925647 as the main case for a 68-69 Vett 3 speed. Doesn't look like it came out of a Corvette. Is yours a 4 speed? I just Googled saginaw 3925658 and a ton of hits came up. Looks like it was a 'B' body 4 speed amoung other apps.
Gary
Old Oct 8, 2009 | 07:58 PM
Avette4me's Avatar
Avette4me
Thanks Gary.
It is a 4 speed. I'm trying to get an assy kit for my shifter and hurst is being a PIA. Just trying to gather as much info as possible for them.
Old Oct 9, 2009 | 02:36 PM
Rich's'78's Avatar
Rich's'78
Your avatar says you have an '80 but from what I have read the Saginaw was only used on '78 & '79s. It hass an iron case and 7 bolt cover. 2 or 3 cuts on input shaft determine close or wide ratios - don't know which. Apparently L48s got the wide ratios.
Old Oct 9, 2009 | 08:59 PM
Avette4me's Avatar
Avette4me
It is an '80. I swapped it from an auto a couple of years or so ago. The transmission and hurst shifter were in a 79, but I thought they only put Muncies in these cars and assumed that both were transplanted.
Old Oct 10, 2009 | 12:36 AM
dburgjohn's Avatar
dburgjohn
I think the same kit will fit all saginaw transmissions. Don't know if you will be able to trace where it came from. GM used it on everything from Camaros to Vegas and Monza. Good transmission as long as you stay below the 200 hp mark.
Old Oct 10, 2009 | 05:50 AM
Avette4me's Avatar
Avette4me
That's what I thought until I talked to Hurst.
I'm well above that and no problems so far.
Old Oct 10, 2009 | 10:24 AM
Duke94's Avatar
Duke94
Found this on the 78-79 Saginaw. As others have said, looks like that's what you got with the L-48 and the BW came with the L-82.
Gary
http://www.hunt4cleanair.net/Articles/fourspeeds.pdf
Old Oct 10, 2009 | 11:47 AM
Avette4me's Avatar
Avette4me
Originally Posted by Duke94 article
When L48 was ordered, the
economical cast-iron Muncie (formerly Saginaw) was installed.
That's interesting. Thanks again Gary.
To Saginaw ID help, please.
