Quadrajet Problems - Car won't slow down
Old Feb 23, 2002 | 11:45 PM
RMS73's Avatar
RMS73
Default Quadrajet Problems - Car won't slow down
Been trying to get my Vette to run properly. When idling the idle port screws now function, but the car will not slow down. I was checking the car out today and had a small burst up to 60 mph. When I let of the gas the car keep running 60 mph. Put the brake on to slow it down and the car would not stop when I pulled into the parking lot; full brakes and it was still moving and the tach was reading 1600 rpm. Turned the key off and quickly checked under the hood and found the carb in proper condition; primary throttle was closed and the choke was opened. Did not find anything hitting the air cleaner. I have drilled a 1/16" hole in the primary throttle plates to get it to idle and to get the idle mixture screws function. Before doing this the car would not slow down sometimes and when it would slow down it was very slow about it. The car is a 73 L-82 with a TH400. I have been fight the quadrajet for months trying to get the car to idle and run properly. Anybody have any thoughts on what to due to the quadrajet? I would like to kept the carb that I have since it is the original and am trying to kept the Vette as original as possible.
Roger
Old Feb 24, 2002 | 12:07 AM
Shark Racer's Avatar
Shark Racer
Default Re: Quadrajet Problems - Car won't slow down (RMS73)
Could be that the choke's stuck open, but it sounds a little crazy. When you have a problem like that, put the car in neutral! You're really killing the master cylinder by putting so much pressure on it. Good luck w/ your problem.
-Steve
Old Feb 24, 2002 | 12:08 AM
Pete79L82's Avatar
Pete79L82
Did you check to make sure the secondaries are not hanging open?
Old Feb 24, 2002 | 12:13 AM
bob's Avatar
bob
Check the fast idle cam on the pass side. The choke can indicate open visually but the fast idle can still be on one notch up.
bob
Old Feb 24, 2002 | 02:13 AM
PatG's Avatar
PatG
Check the springs on the throttle return as well. They can be weak or can hang up if installed improperly.
[Modified by PatG, 12:22 AM 2/24/2002]
Old Feb 24, 2002 | 09:23 AM
RMS73's Avatar
RMS73
The carb has two new springs to close the throttles. In the garage the fast idle cam and weight lever all work very easily. When I got the air cleaner off the air valves over the secondaries were closed, forgot to verify the position of the secondary throttle plate rod, but the connection to the primary linkage on the drivers side was up in the closed position. By the way, I just turned the car off, did not shift it into neutral, It was moving about 5-10 mph when I turned it off.
Roger
Old Feb 24, 2002 | 11:01 AM
ED DINAPOLI's Avatar
ED DINAPOLI
Ckeck to see if you still have the idle solenoid still in place. If it is, adjust your idle using a 1/2" wrench.
Ed
Old Feb 24, 2002 | 12:38 PM
PRNDL's Avatar
PRNDL
Default Re: Quadrajet Problems - Car won't slow down (ED DINAPOLI)
I had a similar problem, and most people suspected problems inside the carb. Finally, a very helpful person showed me where the linkage was getting hung up on the underside of the aircleaner assembly. Problem was, every time I shut off the engine and removed the aircleaner everything looked OK.... duh! MJ
Old Feb 24, 2002 | 05:49 PM
Hershey's Avatar
Hershey
Roger, I know you said that the fast idle cam and weight moved freely, but have you backed off on the fast idle screw where it rests on the cam. also look closely at the linkage from the primary to the secondary. One part of it bends up in front of the secondary lever. Check that there is clearance in betwee the two pieces as the primary side can hold the secondary lever slightly open. Also check your centrifical advance weights in the distributor. I don't think they should create that much speed if they are hung up at full advance, but stranger things have happened. I know it's is frustrating, because all of these things have happened to me at one time or another. Barring one of these fixing it, the next thing is to disconect your linkage and plug all vacuum ports and see if it is anything with the linkage or vacuum. Hershey :confused: :chevy
Old Apr 4, 2011 | 01:19 PM
1980Guy's Avatar
1980Guy
RMS73, please let me know what works for you. I've been having this same problem and I know that it's not my choke being stuck because the choke doesn't even work. It did this before and after I installed an aftermarket air cleaner so I don't think my linkage is getting hung up. Last night I checked the throttle plate and found that it was shut so my guess is that my secondaries are sticking open, perhaps?
Old Apr 4, 2011 | 08:55 PM
sly vette's Avatar
sly vette
Are you aware you have brought up a 9 year old post???
Old Apr 4, 2011 | 08:56 PM
hwcoop's Avatar
hwcoop
ask Cliff he has a good carb forum
http://www.cliffshighperformance.com/parts.html
To Quadrajet Problems - Car won't slow down
