79 Auto to 4spd conversion question
Old Oct 11, 2009 | 10:46 PM
jacobsed's Avatar
jacobsed
Default 79 Auto to 4spd conversion question
I'm looking for some input on where to cut the hole for the stock shifter. Has anyone done a conversion on a 79? Thanks in advance!
Old Oct 11, 2009 | 11:08 PM
Buddy1980's Avatar
Buddy1980
Default 79 4-speed conversion
If you do not have a car to look at regarding the shifter hole, I would simply cut the hole directly under the hole in the 4-speed console plate to match the factory shift boot which has a metal trim plate that screws to the floor.
Old Oct 11, 2009 | 11:28 PM
jacobsed's Avatar
jacobsed
Yea, I don't have a car to look at or a 4spd console plate yet. I getting ready to set the body down on the frame and need to cut the hole.
Old Oct 11, 2009 | 11:33 PM
DZRick's Avatar
DZRick
I have a shifter tunnel from my 68 parts car I can check for you, if you can wait until tomorrow.
Old Oct 11, 2009 | 11:53 PM
jacobsed's Avatar
jacobsed
Thanks for checking. I think 69's had fibreglass floors and 79 had metal floors....not sure if that makes a difference.
Old Oct 12, 2009 | 12:23 AM
DZRick's Avatar
DZRick
I didn't think about that. I'm not sure if there is a difference either. I'm sure a '79 owner will come along that will be able to help you out.
Old Oct 12, 2009 | 06:53 AM
Gordonm's Avatar
Gordonm
Check out this link. He converted to a 5 speed but the hole location would be the same.
http://corvettec3.ca/tko.htm
To 79 Auto to 4spd conversion question
