Automatic tranny question
Old Oct 12, 2009 | 09:29 PM
BB72's Avatar
BB72
Default Automatic tranny question
Ok, not Corvette related . I'm working on my 2000 Blazer changing the automatic tranny. I've always been a manual guy. Just wondering how you know the converter is engaged with the pump?
Old Oct 12, 2009 | 09:48 PM
SIXFOOTER's Avatar
SIXFOOTER
Put the converter on the tranny, turn it until it seats into the pump drive. Then hang the tranny and bolt up the converter to the flex plate
Old Oct 12, 2009 | 09:57 PM
BB72's Avatar
BB72
When I put the converter on it actually slid further back than I needed it too, I had to bring it forward a bit. Does that indicate that it's engaged?
Old Oct 12, 2009 | 10:47 PM
forvicjr's Avatar
forvicjr
The converter should spin and set back a little spin again and should set back to the pump once again. should be close to a half inch from fywheel... while bolting trans up spin converter while tighting trans bolts if converter binds at any time STOP, and start over with engagement or front pump or bellhousing damage will result... VIC....
Old Oct 12, 2009 | 10:51 PM
TimAT's Avatar
TimAT
Put the convertor in and turn it as you push and wiggle. It'll go "clunk" twice. Try and stick you finger between the bottom of the convertor and the case. I'f your finger won't fit and you can see the hub on the front of the convertor is back from the face of the bellhousing, it should be in. As you put the trans in, the bellhousing should easily set on the rear of the block. If it won't make sure the convertor is still free to turn.
Old Oct 12, 2009 | 11:20 PM
BB72's Avatar
BB72
The converter was about 1/2 inch from the flywheel when I bolted it up. Sounds like I got it. Just wanted to check with you guys before I finish this thing.
Rob
To Automatic tranny question
