Tachometer/ Volt Gauge Trouble
Old Oct 14, 2009 | 09:22 AM
ramseygarza's Avatar
ramseygarza
Cruising
Default Tachometer/ Volt Gauge Trouble
hello!
I was replacing the Tachometer's circuit board and was in the process of checking the terminals in the dash. All 3 prongs worked. There was a ground, battery, and voltage from the Dizzy. My volt gauge was working fine as well.
During my inspection, I accidently shorted the circuit. No sparks, smoke, etc. but the volt gauge went to zero - the GEN light came on - I lost voltage from the battery prong - and I get the buzzer when I turn on the headlights.
Did i fry the volt gauge and/or one of those circuit boards?
thanks for the info.
ramsey
Old Oct 14, 2009 | 09:56 AM
speedreed8's Avatar
speedreed8
i would check the gauges fuse first.
http://www.corvetteforum.net/c3/tune.../index18.shtml
Old Oct 14, 2009 | 10:22 AM
Ganey's Avatar
Ganey
Old Oct 14, 2009 | 10:55 AM
ramseygarza
Cruising
i checked the following day and found the blown fuse. easy fix!
thanks for the info. cheers
Old Oct 15, 2009 | 07:43 PM
ramseygarza
Cruising
To Tachometer/ Volt Gauge Trouble
