Park Brake Cable Rubbing Tire
Old Oct 15, 2009 | 04:18 PM
autoist's Avatar
autoist
Default Park Brake Cable Rubbing Tire
I just mounted 255/60R15's on my chassis & the park brake cable to the park brake itself is rubbing the back of the tire...anybody else experienced that? Or know how to sort out?
Old Oct 15, 2009 | 05:29 PM
jersey68l36's Avatar
jersey68l36
It happened to my '68 and never really had it resolved or now, I just have a big hose worm clamp around the cable to keep it away from the side wall. Of course, I don't dare use the emegency brake
The fix is to relocated the emegency cable brackets to on top of the trailing arms.
Old Oct 15, 2009 | 05:57 PM
autoist's Avatar
autoist
Unless somebody has a better idea that may be what I do - cut the bracket off the outboard side of the trailing arm & weld it onto the inboard side.
Old Oct 15, 2009 | 06:11 PM
Ganey's Avatar
Ganey
Normally 255/60/15 fit w/o rubbing & the cable needs to be moved for wider tires.
Old Oct 15, 2009 | 06:13 PM
autoist's Avatar
autoist
I'm hoping its just because we've not aligned the rear end & that will solve the issue.
Ganey: are you saying with 255/60's, the cable should not rub?
Old Oct 15, 2009 | 06:25 PM
Ganey's Avatar
Ganey
Yes, that's the norm & we have had numerous topics on rear tire size!
I am fine w/ 255/60 & have not looked at moving the cable, maybe some repositioning is needed.
Old Oct 15, 2009 | 06:33 PM
'75's Avatar
'75
I have 275 60 15 on the rear and my brake cable was touching the tire, I used a zip tie to hold it closer to the arm.
Old Oct 15, 2009 | 07:01 PM
Ganey's Avatar
Ganey
'75
If that plastic tie breaks, you can expect the cable to cut through that tire fast. If you don't want to move the cable, then consider adding another clamp w/ some rubber or at least a steel cable w/ a piece of rubber hose.
PS 275 does not increase the contact patch area.
Old Oct 15, 2009 | 07:16 PM
'75's Avatar
'75
275 is what was on the car when I bought and I see no reason to replace them. No worries about the zip ties, tehyre the wide ones, and no it won't cut the tire anyway, it's a round cable housing, at worst it will get the cable a little warm.
Old Oct 15, 2009 | 08:29 PM
autoist's Avatar
autoist
Here's a photo of the cable where it rubs the tire:
Old Oct 17, 2009 | 02:03 AM
boat196's Avatar
boat196
I had same issuse, on my 1970 with the 255/60. I've tryed bending and prying the cable with no luck.
Bob
Old Oct 17, 2009 | 01:15 PM
autoist's Avatar
autoist
Well, I've decided....I'm going to reposition the cable to run up the inside of the trailing arm instead of the outside & reposition the bracket to the top of the trailing arm....might as well solve the problem correctly the first time & while my body is still off the chassis.
Old Oct 17, 2009 | 02:43 PM
Artsvette73's Avatar
Artsvette73
Pretty much what was suggested to you on another forum
Old Oct 17, 2009 | 02:59 PM
autoist's Avatar
autoist
Yep, & the best idea I've gotten from both forums.
Old Oct 17, 2009 | 08:24 PM
Clams Canino's Avatar
Clams Canino
I had the same two zip ties in place for 20 years, almost forgot it until this thread.
When I get done.. I plan to use 2 newer and bigger ones with some epoxy. I'll just check it every once and a while.
-W
Old Oct 18, 2009 | 11:27 AM
kellyr073's Avatar
kellyr073
Originally Posted by Ganey
'75
Can you explain why? Based on this website, it looks like another 0.8" in width. http://wheelsmaster.com/rt_specs.jsp
Old Oct 18, 2009 | 11:52 AM
noonie's Avatar
noonie
My 75 rubs, my 77 did not. Both with Goodrich 255 60
To Park Brake Cable Rubbing Tire
Old Oct 18, 2009 | 12:10 PM
mrvette's Avatar
mrvette
15 years ago when fitting 275/50/17 on the stock wheel centerline, but 9/5 inch rims....so that was 3/4 more toward each side of the wheel, and of course a tad more on the tire.....I moved the ebrake to behind the rotor and moved the frame mount shroud ends to the outer end of the thwart....I still had to take a large flat washer with a hole in outer edge, mount to the lower shock bolt, and put a good stiff spring on it to the cable shroud....holding it off the tire....
I could not seem to fit the cable on to the top of the t-arm, although everyone else seems to do it fine....
my car is a '72, via St. Louis anyway....
Old Oct 18, 2009 | 02:05 PM
Ganey's Avatar
Ganey
Yes. A long time ago I did a topic called Tire Test to do that. Multiple choice w/ 3-4 tires listed w/ a speed rating thrown in on at least 1.
The patch is the same size, only the shape changes so that as the tire is changed from a narrower tire, the patch runs front to back, to a wider tire the patch is out side to side.
Guys were guessing. Only GM chassis engineer ddecart replied correctly (by e-mail instead of posting).
Old Oct 18, 2009 | 03:49 PM
71coupe454's Avatar
71coupe454
I put 255/60-15 Eagles on my 71 and the cables just barely touched the tire. I was able to tweek the cables by hand and they clear fine now. I'll recheck it and maybe do something more if needed after I get it drivable.
