Hydraulic Hood Lift?
Old Oct 15, 2009 | 06:08 PM
Dantana's Avatar
Dantana
Default Hydraulic Hood Lift?
The fiberglass lip on my fender sheared off because someone forgot to put the support plate on, I assume previous owner.
Anyone ever try this sort of thing instead of re-glassing and using the stock set up?
http://www.g20style.com/How_to%20Con...od%20lifts.htm
Old Oct 15, 2009 | 06:38 PM
'75's Avatar
'75
Yea, Durango_Boy did it a few years back.
http://forums.corvetteforum.com/c3-g...od-struts.html
Old Oct 15, 2009 | 09:34 PM
Artsvette73's Avatar
Artsvette73
You will quickly find out that those hydraulic cylinders are under some extreme pressure. And the fiberglass will be the weakest link.
Old Oct 15, 2009 | 11:01 PM
73'Vette's Avatar
73'Vette
I have this kit installed:
Hydraulic hood lift
Look at the bottom of page 7.
Old Oct 16, 2009 | 09:38 AM
jimvette999's Avatar
jimvette999
Hydraulic hood lift
$136.50 Think I'll wait for the half price sale
Old Oct 16, 2009 | 04:21 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I was thinking about buying that kit until I thought how do you close the hood. For me I drop the hood from about 3-4 inches and it closes perfectly every time.
If you have the hydraulic support with pressure in it do you have to push the hood down one side at time ?
Old Oct 17, 2009 | 12:44 AM
73'Vette's Avatar
73'Vette
Nope. Just drop the hood down like you would normally do. It's a great kit, easy to install, and functions well.
Old Oct 17, 2009 | 08:32 AM
worship79's Avatar
worship79
Did the set come with bolts or did you have to re-use your original ones?
Old Oct 17, 2009 | 09:54 AM
73'Vette's Avatar
73'Vette
It comes with everything you need to do the installation....bolts are included.
Old Oct 17, 2009 | 07:37 PM
76 sting's Avatar
76 sting
got the same one works perfect installs n minutes
Old Oct 17, 2009 | 10:46 PM
MotorHead's Avatar
MotorHead
I guess I don't understand how it works then. How does it hold the hood up and allow you to drop it down at the same time ?
Old Oct 17, 2009 | 11:06 PM
eagle275's Avatar
eagle275
I wonder why it won't work on a '71 w/L-88 hood?
Old Oct 18, 2009 | 12:09 PM
73'Vette's Avatar
73'Vette
It's all about geometry.
Old Oct 18, 2009 | 01:07 PM
MotorHead's Avatar
MotorHead
That clears is up
Old Oct 18, 2009 | 01:19 PM
73'Vette's Avatar
73'Vette
I'm not sure what you are wanting to know. It works the same way any other hydraulic lift works. For instance, my daily driver has a rear hatch that uses hydraulic lifts. I open the hatch, and the lifts hold it open. When I want to close the hatch, I just exert some pressure, which changes the angle of the hydraulics allowing it to close.
Old Oct 18, 2009 | 04:02 PM
71coupe454's Avatar
71coupe454
Hey is there any ID on the shock part? like a name and part #? Looks like a great set-up. I just hate to pay over a hundred bucks for the hardware.
Old Oct 18, 2009 | 04:09 PM
MotorHead's Avatar
MotorHead
If I install this unit from Speed Direct can I drop my hood closed from 3-4" no pressure exerted, as in, it closes under it own weight like it has for 30 years or will the pressure in the hydraulic cylinder prevent me from doing this ?
To Hydraulic Hood Lift?
Old Oct 18, 2009 | 04:25 PM
73'Vette's Avatar
73'Vette
Yes, you can drop the hood from 3-4" with no pressure exerted. The only pressure you need to exert is when the hydraulic cylinder is at full extension, which is when the hood is fully open. Once you break the angle at which it holds the hood open, the hood drops down like it has always done with the old mechanism.
Old Oct 18, 2009 | 04:35 PM
MotorHead's Avatar
MotorHead
Thanks I think I might get one now
Old Oct 19, 2009 | 06:45 PM
Dantana's Avatar
Dantana
I think I defintely will get one too. Exactly what I need! Great tip!
Thanks,
Dan
