ATTN differential GURUS
Old Feb 24, 2002 | 07:01 PM
boredsoIstrokedit's Avatar
boredsoIstrokedit
Default ATTN differential GURUS
Does anyone know where to get a carrier for an 80-82 differential that will carry 4.88 gears?
Old Feb 24, 2002 | 07:59 PM
Chris69's Avatar
Chris69
Default Re: ATTN differential GURUS (chuckb01)
80-82 uses the one piece cover/crossmember, limiting the size of the carrier to a stock Dana. Never seen anything different to replace that.
Old Feb 25, 2002 | 03:00 PM
boredsoIstrokedit
Default Re: ATTN differential GURUS (Chris81)
ttt?
Old Feb 25, 2002 | 03:14 PM
mrvette's Avatar
mrvette
Chuckie, 488 tells me you into dragracing...fine, but those entire rear assy's are not as strong as the earlier iron ones'.....Isuspect you can/will break a housing or two, maybe even a mounting strut....
I think you need either go to an earlier style rear, or do a tub out solid axel....488 is unstreetable, basically....
GENE
Old Feb 25, 2002 | 07:53 PM
79Corvette02's Avatar
79Corvette02
Randy's Ring and Pinion-they've got them. I talked to one of the guys and they have up to a 5.36 (5.38 I can't remember). I know they have them for the drop out iron setup's, I'm not sure if they'd have them for the later ones, biut I'd give them a shot. Good luck
Old Feb 25, 2002 | 08:33 PM
boredsoIstrokedit
Default Re: ATTN differential GURUS (79Corvette02)
im not into drag racing necessarily, but with the double overdrive 6 speed on the way, i can run 4.88 gears and still cruise at about 2200 at 70mph. I would love the low end punch and the tire tearing that comes with the 4.88 gears. 79Corvette02, do you have a link or a phone #?
To ATTN differential GURUS
