4 speed swap?
Old Oct 19, 2009 | 04:08 PM
Al Davis's Avatar
Al Davis
Default 4 speed swap?
I have a 79 auto and want to use the original parts like the Super T 10, factory everything to look original. This trans will be behind a 383 400hp and 450tq engine, Will the 4 speed trans handle it or should I just build up the automatic I already have?
Old Oct 19, 2009 | 06:21 PM
Dantana's Avatar
Dantana
I once ran 400+ hp in front of a Super T-10 in a camaro. No problems with the trans. The frame on the camaro is another story altogether.... let's just say I had trouble closing the doors and fitting the tops back on.
Old Oct 19, 2009 | 09:43 PM
Al Davis's Avatar
Al Davis
Default 4 speed
anyone here ever done a swap? Any tricks?
Old Oct 20, 2009 | 01:57 AM
71coupe454's Avatar
71coupe454
I'm most of the way through my conversion. Not a big pain, just a lot of bits & pieces needed. I was able to get most of them from Wilcox. Theres lots of threads in here on the subject.
Old Oct 20, 2009 | 03:50 PM
cube57's Avatar
cube57
3rd Gear
I'm considering converting my 79 to a big block 4spd. Will a M21 work just as well as a
ST10? Will I need fab a tranny mount because of the shorter trans? What mods will I have to make for a shifter?
To 4 speed swap?
