cuts out when 4 barrel opens
Old Oct 19, 2009 | 05:14 PM
TonyLe's Avatar
TonyLe
Default cuts out when 4 barrel opens
I swapped my duel point for a HEI and put a Holley 650 on my 350.
Ran great for a while now it cuts out when i lay into it a bit.
Checked float levels and timing. Could the distributer be bad?
Old Oct 19, 2009 | 07:27 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would start by removing the air cleaner, start the car and blip the throttle hard enough to open the secondaries while looking down the carb. Do you see fuel flowing from the secondary venturis? If that's OK, I'd check total advance.
Old Oct 19, 2009 | 08:49 PM
TonyLe's Avatar
TonyLe
vacuum secondaries. Will they or should they open without a pull on the motor?
Old Oct 19, 2009 | 08:58 PM
SIXFOOTER's Avatar
SIXFOOTER
Vacuume secondaries will not open sitting in the driveway.
Old Oct 20, 2009 | 03:16 PM
0Paul Ruggeri
Former Vendor
I've done it many times. You have to hit the throttle pretty hard to get the vacuum secondaries to open, but it can be done.
Old Oct 20, 2009 | 05:26 PM
MelWff's Avatar
MelWff
It probably depends on which spring is in the housing. The light pressure short yellow spring will probably show motion but as you get to the stiffer springs I doubt you will see anything.
Old Oct 20, 2009 | 06:01 PM
Project80's Avatar
Project80
Does it cut out while sitting in the driveway (rev. it) or just on the highway?
Is this a new Holley or just new to the car?
Old Oct 20, 2009 | 06:16 PM
dmayhew's Avatar
dmayhew
Have you checked the float level? If the fuel level is too low on the rear bowl, then you may be getting too much air w/no fuel mixed with it.
David
Old Oct 20, 2009 | 07:33 PM
0Paul Ruggeri
Former Vendor
Could be unrelated to the carb, like a bad plug or wire.
Old Oct 21, 2009 | 12:48 PM
TonyLe's Avatar
TonyLe
Only does it under a load. Works fine in the driveway, but not as much fun. Is a new carb and float levels are fine. I think it may be in the distributer. Gonna try a different one to find out. New plugs, wires, dist, and carb only has about 600 miles on them.
Thanks for all the responses. This is a great Forum.
Tony L.
Old Oct 21, 2009 | 04:12 PM
baxsom's Avatar
baxsom
i dont rememeber exactly who but on this site someonewhere it was said that if you can get the vacuum secondaries to open in the driveway then your spring is too light.
also maybe the pump cam needs adjustment. rarely is a holley perfect out of the box
Old Oct 21, 2009 | 04:55 PM
Iroc57's Avatar
Iroc57
Of course you may have to pencil in your eyebrows after doing this if you advance your timing
Old Oct 21, 2009 | 06:14 PM
Project80's Avatar
Project80
I know this is really basic but, is there a fuel filter that may need replacing?
Old Oct 21, 2009 | 10:29 PM
Duane4238's Avatar
Duane4238
Is it cutting out as in "the engine quits" and you have to restart? OR is your engine bogging down when you get into it, and then recovers after the bog? If it's a bog, you need to experiment with a Holley secondary spring pack. The bog is usually caused by the secondaries opening at the wrong time on those vac. sec. Holleys. And, the new carb never seems to come with the correct spring installed for your application. Good luck!
Old Oct 22, 2009 | 05:36 AM
baxsom's Avatar
baxsom
that is what is nice about the street avenger series or the demons if you go square bore.
extra springs and they are easy to change
Old Oct 22, 2009 | 08:05 AM
70BBvert's Avatar
70BBvert
Check the wires on the pick up coil as well. They tend to crack & break at the coil and will cause the engine to cut out and/or hesitate on acceleration.
Jim
Old Oct 22, 2009 | 11:45 AM
TonyLe's Avatar
TonyLe
Under load it would spit and spudder and not recover until i let off the pedal. Then run great, could the vacuum advance cause that?
Tony L.
Old Oct 22, 2009 | 01:03 PM
Matt Gruber's Avatar
Matt Gruber
Jim
good advice.
or put the point dist back in for a check
Old Oct 22, 2009 | 04:42 PM
70BBvert's Avatar
70BBvert
Tony L.
Yes, the vacuum advance rotates the pick up coil. If the wires are cracked it can cause those symptoms. Easy to mistake for a carb problem. Look closely at the wires at the pick up coil. Not the coil in the cap. If it is the problem you'll need to pull the distributor to repair. You can buy just the pick up coil, but sometimes the shaft is gummed up enough to not come out very easily, or without removing the upper bearing with it. BTDT
Jim
To cuts out when 4 barrel opens
