Horn Parts Question
Old Oct 22, 2009 | 10:10 PM
base1957's Avatar
base1957
Default Horn Parts Question
I am trying to rebuild the upper parts in my horn. I have a c3 column and believe it to be a 75. when I look to order parts or Horn contact kit ecklers has a 69-74 and wilcox has a 75 to 82. I have looked at Jims pics and mine has the metal hub he noted on the 69-75.
So which kit is correct?
Lost without this forum
Old Oct 22, 2009 | 11:11 PM
'75's Avatar
'75
I find that both list for 75-82
http://willcoxcorvette.com/product_i...ducts_id=25181
http://www.ecklers.com/product.asp?p...5&dept_id=1714
These are what's in my 75
Old Oct 23, 2009 | 11:49 AM
Jim Shea's Avatar
Jim Shea
The tilt & telescoping upper horn contact (#3) is the same (GM #3949103) for the model years 1969-1982 with one exception the Vega steering wheel in 1976.
The spacer (#8) is a bit confusing. It is (GM # 3952781) from 1969 through 1974. The 1975 AIM was revised changing the spacer to GM #348325 There was not a spacer required in 1976. The GM #348325 was again used from 1977 through 1982. The following drawing should read 1969 through 1974 since the spacer changed in 1975.
I do not have any information on the two different spacers. But since none of the other parts sorrounding the spacer changed in 1975, I suspect that maybe the spacer pads got just a bit longer in 1975 and maybe allowed the assembly plant to use less shims (#4) to get the horn cap aligned correctly.
Jim
Old Oct 23, 2009 | 01:02 PM
base1957's Avatar
base1957
thanks for the info Jim
I've enclosed a pic to help identify.
http://i168.photobucket.com/albums/u...vette68008.jpg
what is a sure way to tell if you have 76. I'm trying to determine which shim(s) and or spacers to buy.
thanks
Old Oct 23, 2009 | 04:57 PM
Jim Shea's Avatar
Jim Shea
base1957,
The link you posted takes me to my Photobucket account.
Jim
To Horn Parts Question
