Phoenix Brake Bleeder
Old Oct 23, 2009 | 04:12 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Phoenix Brake Bleeder
Is anyone familiar with the Phoenix Brake Bleeders? It's a reverse bleeder system that seems to make sense. Since air is lighter than brake fluid it bleeds the brake system from the calipers to the master cylinder.
thanks
Old Oct 23, 2009 | 04:46 PM
Gordonm's Avatar
Gordonm
Get a Motive brake bleeder. Way better than the Phoenix. I have had both and tossed the Phoenix in the can. It sounded good but the Motive blows it away
Old Oct 23, 2009 | 04:52 PM
jrzvette's Avatar
jrzvette
I have a Motive that i use on my C4 but I would have to buy an adaptor for the MC on my C3. Also, I have speed bleeder valves on the C4 so I don't think I could use the Phoenix with them. Am I right?
Old Oct 23, 2009 | 05:54 PM
Jeff_Keryk's Avatar
Jeff_Keryk
The best Phoenix brake bleeder is a Motive brake bleeder.
Old Oct 23, 2009 | 08:29 PM
OzzyC4's Avatar
OzzyC4
Why would you want to push the dirty fluid back into your system, especially if you have ABS?
I'll never reverse bleed any of my vehicles.
Old Oct 24, 2009 | 11:00 AM
jrzvette's Avatar
jrzvette
I think it's to be used to bleed the hydraulic system not to flush it.
Old Oct 24, 2009 | 12:59 PM
Gordonm's Avatar
Gordonm
The adapter they sell with the Motive I think is terrible. I made my own out of a flat piece of 1/4 inch steel. I did use their rubber piece from the adapter but the plastic tip broke off and to clamp it tight enough you really need to clamp it tight. I did not like the plastic piece. It cost me nothing but a little time and drilling and tapping a hole.
Old Oct 24, 2009 | 01:58 PM
jrzvette's Avatar
jrzvette
can you post a picture of the adaptor that you made?
Old Oct 24, 2009 | 02:31 PM
TJP440's Avatar
TJP440
I've got one and We've used it a few times but really wasn't that impressed with it. It just sits on the shelf collecting dust. probably should put the thing on sleaze bay
To Phoenix Brake Bleeder
