Steering Problem 1981
Old Oct 24, 2009 | 08:12 AM
Iskenderian's Avatar
Iskenderian
Default Steering Problem 1981
Greetings from Iraq,
I am writing on behaf of my father who is working on my C3 for me. For the longest time its had an unexplained pull to the right. Long story short when jacked up he started the car (front wheels removed) and the wheel turned itself to full right lock rather quickly.
My question is, what could cause this, he replaced a balence valve (see pic) to no effect. I had in the past replaced the steering piston (not sure of technical name but looks like a shock absorber on the steering system. any ideas?
edit: i didnt realize this part could be adjusted. I'll let him know and maybe that can fix it.
Bob
Old Oct 24, 2009 | 08:20 AM
Hootisit's Avatar
Hootisit
If the control valve has been replaced. It sounds like it needs to be balanced out. The process for balancing the valve is in the service manual. It's relative easy to do. There are threads on the forum also, that would help you. It sounds like the manufacture of the valve never balance it before shipping.......
Old Oct 24, 2009 | 08:28 AM
Duke94's Avatar
Duke94
Yep, balance the control valve and you'll be good to go.
Gary
Old Oct 24, 2009 | 08:31 AM
killer454's Avatar
killer454
you need to take the car in for a front end allignment they will tell your father if anything is bad on the front end.then he can decide if he wants to fix it or let them.there are a number of things that could cause this pull to one side.(just needs an allignment,bad tie rod,ball joints,idler arm,wheel bearing bad,break caliper sticking.
these cars have a fast ratio gear box for the steering so this is normal.
as long as you dont hear noise when turning the wheel this is normal i do beleive.
Old Oct 24, 2009 | 08:47 AM
Gordonm's Avatar
Gordonm
No they do not have a fast ratio gear box and this is not normal to have it turn itself full right quickly. There is no way any car manufater would let this happen. The safety board would be all over this. I agree with the above. Adjust the valve. There also might be some front end alignment issue but if it is moving right or left without touching the wheel the control valve needs adjustment.
Old Oct 24, 2009 | 09:22 AM
Jim Shea's Avatar
Jim Shea
Self steer would almost have to be a control valve balance problem.
BTW, along with the above list of possible causes, a bad tire can also cause a pull in one direction or another. Swapping tires side to side will cause the pull to change direction. It won't tell you which one it is, but it will give you a real good indication of the cause.
Jim
Old Oct 24, 2009 | 09:54 AM
Iskenderian
i guess i left some info out,
the whole front end (ball joints bushings etc) has been replaced. and the car has been aligned. according to the shop it was in spec. they could have been blowing smoke i suppose,
the other thing the car self steered to the right before he replaced this part and does the same after. (no change)
thanks for all the info
Bob
Old Oct 24, 2009 | 11:04 AM
killer454's Avatar
killer454
im sorry i thought he was saying his car was pulling to the left when driving it.
did not understand the post right so disregard everything i said
i apoligize for the incorrect help
Old Oct 24, 2009 | 11:23 AM
Al Davis's Avatar
Al Davis
Hello from Chicago, being that you are in Iraq I would think that you are in some branch of the Armed Forces. If so, we support you and all the men and women in the Military. Stay safe. I am in the same boat. I have the new valve but also have been reading about all the strange things this valve can do. I am thinking about having a mechanic do it on a lift.
Old Oct 24, 2009 | 03:09 PM
Iskenderian
adjustment worked ! steering is neutral now.
Bob
To Steering Problem 1981
