Hey out there! I have a question: what's the difference from a #3857584 tailshaft last used on a 70 Vette, and a #3978764 tailshaft used from 71 thru 74 Vettes? Thanks!!!
Thanks for the info Duke. I was under the impression that all muncies after 70 were the 32 spline, so I was thinking the difference was in shifter mounting or something like that. Should I be thinking the only difference- and spline count is a BIG difference- is the spline count, and not shifter mounting?
I can use a 27 spline muncie if I just get a driveshaft with 27 splines, it seems to me. Duh. And if there is any difference in shifter mounting, I should be able to get the right plate to adapt the earlier tail. Right?
I copied that page you sent me about casting numbers and thanks again!
Thanks Roger! Here's what I also found out after looking at my Volunteer Corvette catalog: shifter brackets are the same from 68 to 82, so one would have to say the mounting bosses on the tailshaft are the same. You all have been great!
