Windshield trim removal
There is a trick too it though, so you don't break the plastic trim clips.
Patience is a must.
http://shop.advanceautoparts.com/web...%7CGRP2083____
Patience is a must.
A cross section view of how the clip fits inside the trim would be helpful.
You carefully slide the pioint of the tool under the the trim on either side of the clip, all the way to the outside edge of the trim. Then slide it over to the clip, and gently push the tip of the tool between the outside edge of the trim and the clip, till the trim pops up. Start in the middle of the trim piece and work towards the ends.
