Brake Rotor/Hub Question
Old Oct 27, 2009 | 01:43 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Default Brake Rotor/Hub Question
I'm building a '64 mid-year and am looking at converting-over to front disc brakes. I got a pair of '68-'82 spindle, steering arm, rotor/hubs. It appears that the rotors are rivited to the hubs, Can I grind the rivits off from the inside to separate them, or am I stuck with the combination? Thanks for any help to a guy from the C-2 side.
Dave64
Old Oct 27, 2009 | 03:04 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
dave you drill them out from the out side and then they seperate.....the trick guys then tap the holes and use counter sunk set screws to fasten the rotor to the hub after shimming for runout......or the rest of us just put them on and hope for the best. you need to be aware that the rotor run out with the calipers will cause the original lip seals to suck in air....the o ring seals do not have this issue......so if after you are all finished and you cant explain why you get a mushy pedal feel after having firm brakes and bleeding always fixes the problem check for rotor runout...or just bleed the offending rotor/caliper when it get mushy.
Old Oct 27, 2009 | 03:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Index the rotors before removing the rivets. Reassemble with your witness marks and run out will be minimized.
If you are intending to have your '64 judged, you do not want to make this swap.
Old Oct 27, 2009 | 04:46 PM
Dave64's Avatar
Dave64
My car is a restorod. I got the hardware for some old Chevelle parts and was hoping this wouldn't be a real expensive upgrade.
Why would I need to resecure the rotors to the hubs? Did all you guys have to go thru this when it came time to replace your rotors? When I replaced rotors on my '95 Chevy truck, I just put the new ones on the hubs and that was it. I'm not arguing, I'm just asking.
Also, when I look in the Mid-America, Zip, etc and all they're selling are hubs and separate rotors.
Dave
Old Oct 27, 2009 | 04:59 PM
Peterbuilt's Avatar
Peterbuilt
You don't have to replace the rivets the lug nuts will hold them on, but you must index the rotor and hub or you may have run out problems. PG.
Old Oct 27, 2009 | 05:34 PM
Dave64's Avatar
Dave64
OK, index. Do you mean ensure the rotor goes back o the hub in the same location? If so, I got that and understand.
Now, Bob, you mentioned shimming them. Why would I need to shim the rotors - or do you shim them if replacing them with new rotors?
Old Oct 27, 2009 | 06:47 PM
Peterbuilt's Avatar
Peterbuilt
Yes, put the rotor back on the hub in the same position it came off. When GM built our Corvettes the rotor and hub came as an assembly to insure that they were true.
You only need shims if you have run out. Check out part 12 & 13 on this link for more information on C-3 brake run out. http://www.idavette.net/Hib/vette_BBFH.htm PG.
Old Oct 27, 2009 | 07:04 PM
Ironcross's Avatar
Ironcross
you may have overlooked something and that is the 68 parts are the same as 65-67,,,,69 and later [ie] 82`s are the same however......spindles are different!
Old Oct 27, 2009 | 07:07 PM
Dave64's Avatar
Dave64
The '69~'82's have the larger diameter spindle/bearings, right? I've got the larger diameter spindles. Thanks for all the help. Now, I guess I need to get the rotors mic'd. They may not need to be replaced at this time.
Dave
Old Oct 27, 2009 | 07:11 PM
Ironcross's Avatar
Ironcross
Dave
It is not a hard job as some will have you believe. And your exactly correct, just treat the system as a front wheel drive vehicle. The wheels will hold the rotors to the hubs, same as the FWD`s
Old Oct 27, 2009 | 07:36 PM
Dave64's Avatar
Dave64
Thanks Wally. Pleasant surprise to see you over here.
To Brake Rotor/Hub Question
