brake booster bad???
Old Oct 27, 2009 | 10:37 PM
colin75's Avatar
colin75
Default brake booster bad???
when i shut off my car i hear a vacum leakdown from a hole located on the underside of my master cylinder close to the booster. is this a sign that my booster is leaking?
Old Oct 28, 2009 | 12:28 AM
71coupe454's Avatar
71coupe454
I dont know how that would be possible.. check the hose going to the booster, or it may be leaking inside the booster?
Old Oct 28, 2009 | 08:09 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
It would have to be coming from the booster, there's no vacuum within the m/c
Old Oct 28, 2009 | 12:27 PM
colin75's Avatar
colin75
right where the master cylinder is bolted to booster there is a small hole in the bottom of the master cylinder. thats where air is being sucked in.
Old Oct 28, 2009 | 06:10 PM
'75's Avatar
'75
If you pull the nuts off that mount the mastercylinder and pull it forward with the lines still attached, you will see this seal. Probably the seal is worn and the rod is rust pitted causing your vacuum leak.
PS. You won't find a new seal at the regular parts places. If you contact a rebuilder, he may sell you just the seal, it's a lot easier to get a new booster.
Old Oct 28, 2009 | 11:03 PM
colin75's Avatar
colin75
ive always had a soft pedal. new booster will be on my wishlist. thanks and i will inspect just to see.
Old Oct 29, 2009 | 12:53 PM
SSG26K's Avatar
SSG26K
A bad booster will give you a hard pedal not a soft one.
To brake booster bad???
