Hood clearance with crate engine
Old Oct 29, 2009 | 11:38 AM
LT2300's Avatar
LT2300
Default Hood clearance with crate engine
I'm looking at the FastBurn 385 (turn-key on ZZ4 short block). Can anyone tell me about hood clearance in a '69?
My front end was recently trashed and is being fixed, so I can replace the hood with whatever it takes. The shop doing the body work isn't sure if even the big block hood will provide enough clearance.
From GM's pictures, it appears that the high-rise, Holley and air cleaner on the FB385 is a whole lot higher than the existing Performer, QJ and stock air cleaner, but I know appearances can be deceiving.
I've checked with GMPP and their nearest local dealer, and can't get any information about height, either overall or heads up.
Anyone know for sure what it will take?
Old Oct 29, 2009 | 01:27 PM
MelWff's Avatar
MelWff
Your best bet would be an L88 hood. You may have to cut into the air box under the hood. I have a 69 with a 70 LT-1 running a Edelbrock RPM Air Gap, Holley 780, factory drop base air cleaner with a 4" tall air filter.
Old Oct 29, 2009 | 01:35 PM
Ganey's Avatar
Ganey
68-72 standard hoods have limited clearance so that's why the Performer. There needs to be at least about 3/4" clearance over the Holley vent tubes. The LT-1/BB hood is really the minimum for the SB high rise intakes.
http://forums.corvetteforum.com/c3-t...er-intake.html
Old Oct 29, 2009 | 03:36 PM
LT2300's Avatar
LT2300
Default To MelWff
This link shows the FB385. How does the picture compare to your mainfold, carb, AC?
http://www.gmperformanceparts.com/En...9710&engCat=sb
Old Oct 29, 2009 | 04:17 PM
FKING1's Avatar
FKING1
The ZZ4 long block with Holley 650 Street Avenger would not clear the hood on my 70.
Had an L88 hood scoop added and problem solved.
Looks cool too.
Old Oct 29, 2009 | 04:31 PM
MelWff's Avatar
MelWff
Looking at the link picture the RPM Air Gap is taller and the air filter in the picture is 3" I'm using a 4". Remember though I cut the L88 air box to clear the 14" diameter air cleaner
Old Oct 29, 2009 | 05:35 PM
DZRick's Avatar
DZRick
The FastBurn 385 will fit under a LT-1/BB hood, I have one in my '68.
If you'd like I can put a straight edge across the fender channels where the hood sits and measure how high above them the top of my air cleaner is.
Old Oct 29, 2009 | 06:41 PM
LT2300's Avatar
LT2300
Default Thanks
Thanks to all for input and help.
My entire front clip is trash, so there's no measurement. I just remember putting a Holley Projection on top of my Performer manifold with the smallest air cleaner I could find, and putting cracks in the hood's paint because of interference.
I think another part of the solution will be to get the Holley SHP / LT1 air cleaner base, so it's sitting down a bit rather than right on top of the air horn.
Thanks, again, and I'll keep watching in case there's some later input.
Old Oct 29, 2009 | 06:59 PM
eagle275's Avatar
eagle275
I had to go with an L88 hood for my ZZ4.
Old Oct 30, 2009 | 09:31 PM
Rebelrob's Avatar
Rebelrob
How much of a pain is it to get your aftermarket hood painted and to have it much your possibly 30+ year old paint on the rest of the car... I guess when I say pain I mean $$$?
Old Oct 30, 2009 | 09:43 PM
DZRick's Avatar
DZRick
Using the straight edge method I offered would allow you to measure your hood to see if things would clear. You'd lay your straight edge across the bottom of the hood and measure to the bottom of the hood.
If you don't have a hood I can check my brothers '69 hood against my 385 equipped '68. Otherwise as I said I know for a fact the 385FB fits under the LT-1/BB hood.
Old Oct 30, 2009 | 10:59 PM
eagle275's Avatar
eagle275
The tech guy at Ecklers told me that the L-88 hood has more clearance than the LT-1 hood. I measured from inside the fender of the engine bay, over the top of the air cleaner, to the other side, and found out what I needed. Worked for me.
Old Oct 30, 2009 | 11:52 PM
DZRick's Avatar
DZRick
Nobody is disputing that the L88 hood has more clearance than the LT-1 hood.
LT2300 said "The shop doing the body work isn't sure if even the big block hood will provide enough clearance."
I'm telling you the LT-1/ big block hood does provide enough clearance for the engine in question. That's all. Now he knows he can use either the L88 or the LT-1/ BB hood but he doesn't "have" to use the L88 hood because of clearance issues.
That's the exact engine I have and the front clip/hoods of a '68 are exactly the same as the '69.
What intake is on your ZZ4 eagle? It can't be the one that comes on the ZZ4 from GM if you "needed" the L88 hood.
Old Oct 31, 2009 | 01:16 AM
eagle275's Avatar
eagle275
Default The Edelbrock ZZ4
PERFORMER RPM E-TEC 9.5:1
435 HP & 435 FT/LBS TQ
http://www.edelbrock.com/automotive_...etec_435.shtml
Didn't mean to sound like I had an attitude. I was just telling what I had to do to figure out what hood I needed. The LT-1 hood would not work for me either.
BTW, I wonder what I could do to get even more HP out of this engine? It's a great motor, but I wish I had gotten a BB.
Old Oct 31, 2009 | 01:25 AM
DZRick's Avatar
DZRick
I hope I didn't come off sounding like I had an attitude either. I just wanted LT2300 to know he did have options.
Your engine looks nice and damn that thing is shiny!
That air-gap I'm sure is a bit taller than the GM factory intake that is on mine.
To Hood clearance with crate engine
