which flywheel/clutch
Old Oct 30, 2009 | 12:35 PM
dburgjohn's Avatar
dburgjohn
Default which flywheel/clutch
If I am converting my 81 to 4-speed, which flywheel, clutch and pressure plate should be used?
Old Oct 30, 2009 | 02:26 PM
billsfan's Avatar
billsfan
The flywheel should be 168 tooth, and the clutch should be 11", 26 tooth spline. These are the standard parts for all newer c-3's. Be sure that you don't use an older tranny that has a 10 spline snout. Good Luck.
