LT-1 stuck in reverse
Old Nov 2, 2009 | 01:36 PM
Mortex's Avatar
Mortex
2nd Gear
Default LT-1 stuck in reverse
Yesterday I started my 1970 LT-1 (with a M-21 gearbox) and backed out of my garage. The problem is that I am not able to put it in 1. or any other fwd gears. I can se that the lock out on the shifter is not entirely back in the original position.
Any ideas I might try????
Mortex
Old Nov 2, 2009 | 02:41 PM
Phil Zell's Avatar
Phil Zell
Get under the car and manually put all gears in neutral, then make sure it will shift from inside. Your shifter is in need of adjustment, or repair
