Hood Clearance
Old Nov 3, 2009 | 01:39 PM
sharky69's Avatar
sharky69
Default Hood Clearance
Will an edelbrock performer intake along with a performer carb fit under a 1969 stock small block hood without any modifications? I will also be using the small foam triangular edelbrock aircleaner. Any help is greatly appreciated. The car currently has a pacific performance crosswind (highrise) intake with a qt fuel carb...the original owner wanted to get into racing. Im just trying to get it back to being an everyday driver.
Old Nov 3, 2009 | 04:02 PM
RushThruLife's Avatar
RushThruLife
According to their website it will. If its a airgap it won`t.
Old Nov 3, 2009 | 04:36 PM
Gordonm's Avatar
Gordonm
The intake and carb should fit. I'm not to sure the air cleaner you want to use will fit. You will need a drop base air cleaner to make it fit.
Old Nov 3, 2009 | 05:22 PM
sharky69's Avatar
sharky69
Thats what i was afraid of...
Old Nov 3, 2009 | 06:21 PM
Duane4238's Avatar
Duane4238
The carb and manifold combo should fit. Don't know about the air cleaner you chose, though. I have a performer manifold with a Holley 650 double pumper on my '72. I'm running a drop base Moroso air cleaner and everything just barely fits. I tried the triagular air cleaner but after reading on here about the problems with engine bay fires I tossed it out. Good luck.
Old Nov 3, 2009 | 10:24 PM
76 VETTE's Avatar
76 VETTE
That carb and manifold worked on mine with the stock air cleaner.But the carb kept leaning out so I went back to the original q-jet.
To Hood Clearance
