E-Brake Question
Old Nov 3, 2009 | 07:25 PM
Clams Canino's Avatar
Clams Canino
Default E-Brake Question
True or false:
When assembling the E-brakes; the knurled adjustment **** goes toward the rear of the car.
-W
Old Nov 3, 2009 | 08:09 PM
Maine Vette's Avatar
Maine Vette
I assume you are talking about the brakes on your 68 and that you're referring to the adjusting mechanisim that goes between the two brake shoes. If so, if they're like the brakes on my 71 the knurled part goes toward the front. I've got some pictures of the brakes on my 71 loaded my website. Scroll about half way down the page http://www.corvette-restoration.com/...rm_rebuild.htm
Good luck!
Old Nov 3, 2009 | 09:57 PM
Peterbuilt's Avatar
Peterbuilt
Default This might help.
Sure is a lot easier to change those shoes with the spindle removed!
Old Nov 4, 2009 | 12:02 AM
Clams Canino
Well now we've opend a can of worms....
It seems in Pete's diagram the starwheel faces forward on the right side of the car, and rearward on the left side of the car.
-W (still unsure - both of mine were toward the rear when I took it apart - but that means little)
Old Nov 4, 2009 | 12:17 AM
Peterbuilt's Avatar
Peterbuilt
Default Can of worms!
Clams, not sure where I got that picture but I'll try to verify it is correct or not tomorrow. PG.
Old Nov 4, 2009 | 12:23 AM
Clams Canino
It would help if one side or the other of that pic were flipped top to bottom as well. The way it's laid out you have too look 3 times to notice that left and right are different on the left half of the page from the right half of the page - adding an extra layer of confusion untill you sort out the page.
-W
Old Nov 4, 2009 | 01:04 AM
Peterbuilt's Avatar
Peterbuilt
How about this link: http://corvettemagazine.com/technica...e-rebuild.html Look at #19 Install star wheel of adjuster towards your right hand on both sides.
Old Nov 4, 2009 | 08:30 AM
Clams Canino
Yes... and step 19 agrees with your diagram as well.
However, I will note that step 22 is at odds with step 19.
ie - If the star wheel is on the RIGHT, then one turns it DOWN with a screwdriver to expand the shoes. Yes, I'm sure. I'm looking right at it. Nothing is simple.....
-W
Old Nov 4, 2009 | 08:51 AM
Timsride's Avatar
Timsride
I just did mine a week ago and I installed mine like the diagram, and I think the only reason being I had already done the right side. Then when I installed the left side I wanted it to be adjustable in the same direction of rotation.I almost pulled hubs just to get holding springs in. They should have bigger holes in hub.I wish I had that diagram when I did mine.LOL.
Old Nov 4, 2009 | 11:19 AM
Peterbuilt's Avatar
Peterbuilt
Default Pull up!
Step #22 is correct if you pull up on the screwdriver handle the adjuster will rotate counter clockwise and spread the shoes out.
It's easy to get confused since this is a job that we usually only do once and years later forget what part goes which way. PG.
Old Nov 4, 2009 | 11:25 AM
Clams Canino
Ahhh so. Yes, it's correct regarding the HANDLE. I was thinking blade.
-W (better be doing this only once - heh)
Old Nov 4, 2009 | 12:55 PM
Maine Vette
Does anyone have the chassis service manual handy? Mine is at home and I know it talks about the parking brake setup in detail. If nobody chimes in by this evening I'll post what I find when I get home.
The posts above all seem to make sense though. The starwheel may need to be toward the front on one side, and toward the back on the other...
Old Nov 4, 2009 | 01:37 PM
Clams Canino
Well actually the reason for my question is because other than "correctness" - it doesn't really "need" to be one way or the other.
In the old days of drum brakes the starwheel "needed" to be oriented correctly so tha the automatic adjuster would smack it every time the brakes were applied in reverse. Since that application does not involve our brakes... the question of "correct" arises as an aesthetic thing.
-W
Old Nov 4, 2009 | 03:30 PM
CCrane65's Avatar
CCrane65
-W
As long as you never let anyone else adjust the parking brakes then it doesn't matter but if you have an old timer helping you out he may assume they are installed according to the diagram and turn one star one way and the other the other way and end up with one side not touching the rotor at all.
cc
Old Nov 4, 2009 | 03:45 PM
Clams Canino
Originally Posted by CCrane72
he may assume they are installed according to the diagram and turn one star one way and the other the other way.....
To ****le... The old timer would be wrong.
What we established in this thread and the diagram is that you put them IN oppositely so that you can adjust them in the SAME direction.
-W
Old Nov 4, 2009 | 04:03 PM
CCrane65's Avatar
CCrane65
-W
But you were talking about installing them in the same direction for aesthetics (i.e. both toward the back of the car) which would make one turn the wrong way.
Old Nov 4, 2009 | 07:26 PM
Maine Vette
Well, looks like you guys got it figured out without me having to check the Chassis Service manual. I couldn't see Pete's post (stupid filter at work) but it looks like that diagram pretty much spells it out.
To E-Brake Question
Old Nov 4, 2009 | 07:50 PM
Clams Canino
Well... we sure think we do.
If you consult the manual - you become the final say.
-W
Old Nov 4, 2009 | 09:18 PM
Maine Vette
Ok, you twisted my arm into looking it up. Here are two pages from the 1971 Chassis Service Manual. Looks like the star wheel should be toward the front on the right side and toward the back on the left side.
You'll probably have to view them full size to read the text. Enjoy!
Old Nov 4, 2009 | 10:21 PM
Clams Canino
*I* was yes... but your post presumes the old timer is following the diagram. In which case you described his movements wrongly.
Good try though and thanks for playing.
-W
