Brake power booster
Old Nov 3, 2009 | 10:32 PM
glassman74's Avatar
glassman74
Default Brake power booster
Need to replace booster. 1fordman gave me some insight on the job ahead. Any help or tricks that will easy the pain in the a$$ job?
Thanks in advance. glassman74
Old Nov 6, 2009 | 09:38 PM
mandm1200's Avatar
mandm1200
[QUOTE=glassman74;1572036872] Any help or tricks that will easy the pain in the a$$ job? [QUOTE]
Get someone else do it!!
Remove the drivers seat to get some additional room and maybe some padding to lay on. This is a very do-able job just not a lot of room to work in. It's been about 4 years since I changed mine but I believe there is a clip that has to go on when putting it back together. That was the tough part. As for the 4 nuts, get a 1/4" socket set with a universal joint. If I remember correctly, one of the nuts I was only able to get one click of the rachet at a time. It took a while to get it tight.
Old Nov 6, 2009 | 10:40 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Use a 1/4" drive socket set with long extensions. It aint that bad... I agree the pedal clip is a pita, but you'll get there!
Old Nov 6, 2009 | 10:51 PM
dannyman's Avatar
dannyman
4 nuts, a retainer clip at the pedal and a master cylinder! That's it!
Nothing to it! If your arms are five feet long and 2 inch in diameter!
Old Nov 6, 2009 | 11:55 PM
stock76's Avatar
stock76
One of the four nuts attaching the booster to the firewall and the retainer clip that attaches the brake pedal are the biggest challenges. Not hard to do mechanically but you need patience.
Just double check and make sure you have the retainer clip that attaches the brake pedal back on properly.
Old Nov 6, 2009 | 11:58 PM
MN80Vette's Avatar
MN80Vette
Search for "boost removal" in titles only using Advanced Search. Let us know if you need more tips or help.
Old Nov 7, 2009 | 12:45 AM
jordan89's Avatar
jordan89
All you need is a long extension and one of those flexible elbows for the socket, and lots of patience.
To Brake power booster
