can any one tell me if the dash harness goes in front out the steering column or behind the mounting brackets near the firewall
i pic would be great
thanks
eddie
Check the AIM. For some years, the main dash harness routes above the speedo and tach and clips to the backside of the dash pad to keep it up and out of the way of the under dash braces.
You know you've got it wrong if the harness bumps the braces and will not allow the dash pad to fit properly.
thanks stop on the way home and got a 12 pack from the pic's i had it wrong
and missing a brace. hard to put somthing together that i did not take apart.lol
thanks
eddie
watch that steering column mount, it is cast rough edges, your wires can easily rub on them,
which would be a very bad thing. !
Either grind them smooth, or split some tubing and install over the sharp edges.
or do both ! 69VETT
