neutral safety switch
Old Nov 6, 2009 | 11:07 AM
NMT1957's Avatar
NMT1957
Default neutral safety switch
what are the symptoms of a bad neutral safety switch? No crank when the key is turned?Intermittent starts, how can one test it?Thanks.70 454 auto
Old Nov 6, 2009 | 11:27 AM
...Roger...'s Avatar
...Roger...
At the neutral switch check the purple/white wire for power with the key to start and then the purple for power in neutral and park.
Old Nov 6, 2009 | 11:29 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you can test/adjust it by removing the passenger side panel of the center shift console ......you can test it by using a test light that is grounded and the probe end on the side of the switch on the terminals (passenger side) the rear terminals are the reverse lights and the forward terminals are the safety switch portion......so if the lights light upon both terminals top and bottom you are good to go and the switch is closing .....if it lights up on one terminal and not the terminal above then the switch is "open", the switch is closed when the probe lights up on both sides......do the test with the reverse lights and you will see how it works then apply this logic to the front terminals
Old Nov 6, 2009 | 11:30 AM
NMT1957's Avatar
NMT1957
hey roger can i call you?you sound like you know what your doing.
Old Nov 6, 2009 | 11:31 AM
...Roger...
Sure....937-294-7362
To neutral safety switch
