Rag joint help
Old Nov 8, 2009 | 04:55 PM
Grumpy 427's Avatar
Grumpy 427
Default Rag joint help
I went to install the steering box and rag joint, and it is slightly off. About the distance of the bolt. Now i am thinking this is due to the body mount change, i went from rubber to polly and there may be a thickness issue. I basically bolted the rag joint to the coupler on the steering column, and then forced the box onto the frame. The pins on the rag joint, now hit back and forth on the slots when you turn the steering wheel. Is this an issue?
I can see a couple options here, i can slot the holes on the coupler to line this up, or try to lift the body at the firewall and shim the body mount a bit more .
How much forgiveness is there is there for the rag joint? Or am i making more of this than needs to be.
Old Nov 8, 2009 | 05:46 PM
Mike Ward's Avatar
Mike Ward
I don't see how the pins can hit the sides of the slots unless the rubber disk is loose or broken??
Old Nov 8, 2009 | 06:00 PM
stock76's Avatar
stock76
Did you take a look at Jim Shea's flex coupling articles to see if there was anything that could help you?http://corvette.wikia.com/wiki/Steering. Did your new flex coupler come with the plastic spacers over the pins to help keep the coupler in alignment when installing? Did you leave the steering column loose until you had everything installed and lined up?
I don't understand how the pins would hit from side to side either unless the rubber disc is damaged.
Old Nov 8, 2009 | 06:08 PM
Grumpy 427's Avatar
Grumpy 427
brand new rag, i think i will have to shim the body to get stuff to line up.
Old Nov 8, 2009 | 06:16 PM
Grumpy 427's Avatar
Grumpy 427
Will call Bairs Monday and see what they can tell me.
Old Nov 8, 2009 | 06:18 PM
Jim Shea's Avatar
Jim Shea
The problem when the stop pins bottom out is that you can't tell how much pressure is holding the pin against the window opening in the column flange. What can happen is this:
The pressure on the pin actually causes the column flange to "saw" its way through the pin itself. The interesting thing is that you cannot actually feel the problem in the steering wheel.
Turn the steering wheel one quarter turn and see if the pin is still hard against the window. You really need to look at the pins in two different positions in order to get a sense as to which way the column needs to move to centralize the pins in the window opening.
Loosen the column mounting bolts (both the vertical bolts under the dash and the two nuts on the inside that attach the lower end of the steering column.) This might allow the column to seek a neutral position.
One thing that I do notice is that the flexible coupling is an offshore manufactured part. You might try and reassemble your original flexible coupling in its place. I am wondering if the replacement part may not be as accurate as the original.
BTW, the offshore part has a rubber disc that has four layers of cloth and four layers of rubber. The original Saginaw part was the same thickness but had seven layers of cloth and rubber. The new part would be a lot softer (because of the thickness of rubber) than the original. The steering would feel more direct with the original seven lamination disc.
Jim
Old Nov 8, 2009 | 06:28 PM
Grumpy 427's Avatar
Grumpy 427
Awesome Jim thank you.
Old Nov 8, 2009 | 09:27 PM
Grumpy 427's Avatar
Grumpy 427
Well i added a couple of body mount shims, and dropped the steering column. Problem solved.
Old Nov 9, 2009 | 08:39 AM
Jim Shea's Avatar
Jim Shea
Coupling Disc 101 - just a bit more technical information.
There were basically two different constructions: One with seven laminations of cloth and rubber; the other with four laminations of the same material. The discs had the same dimensions for thickness and diameters. So the seven ply disc just had a lot less rubber with the addition of the extra cloth. Since the disc dimensions were the same, all of the flexible coupling hardware was the same between the power versus manual applications (except the flange itself that attached to the 3/4 shaft for manual steering or the 13/16 flange for typical integral power steering gears.)
The disc with seven laminations of cotton cloth and neoprene rubber was known as the "manual steering" disc. This disc was mostly cloth with thin layers of rubber holding it together. It was quite stiff and was quite durable. It would provide a somewhat more precise feel of the road because it was so stiff. This was the primary reason that Corvette specified the seven ply disc on all Corvettes regardless if they had power steering or not.
The other disc was with four laminations of neoprene rubber and cotton cloth. This was known as the disc used with power steering. Most power steering systems (unlike the Corvette) had the hydraulic valve built into the input side of the gear. If there was no isolating element in the steering shaft connection, hydraulic fluid noise could travel up the gear input shaft, up the steering column shaft, and up into the driver compartment. (The hydraulic noise could be quite annoying.) The four ply disc did a much better job of isolating the hydraulic noise and keeping it in the engine compartment than the seven ply disc. Since power steering reduced the amount of steering effort, the fact that the four ply disc was "softer" than a seven ply disc was not all that important on most GM cars and trucks.
Since the 1963 through 1982 Corvette used the "valve and adapter" type power steering, the hydraulic valve was down on the relay rod and not directly a part of the gear. This tended to isolate the hydraulic noise to the engine compartment, (more than a typical intergral power steering gear.)
Jim
To Rag joint help
