engine noise
Old Nov 9, 2009 | 10:29 PM
wtbrs123's Avatar
wtbrs123
Default engine noise
79 vette L-82 350 with four speed with 67,800 miles.
cranked up engine last week heard noise shut engine down checked fluids all was good re cranked engine checked oil pressure 60 to 65lbs idle fast idle 80lbs.
noise sounds like ball pin hammer taping and bouncing on steel beam
inside the car it sounds like an exhaust leak or maybe a valve clacking.
I'm no mechanic be any stretch I'm also hard of hearing and wear hearing aids so the sound might be some what different to someone with good hearing.
would appreicate your thoughts.
Old Nov 9, 2009 | 10:38 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well a valve train issue comes to mind.....pull off the valve covers and see if any of the stamped steel rockers are broken or if a pushrod has bent
Old Nov 10, 2009 | 04:16 PM
wtbrs123's Avatar
wtbrs123
I pulled the covers the valve train looks fine and the the push rods appear to be straight.
I disconnected the coil and turn the engine several times checked valve train and rods again looks good.
I don't drive it much so there might be some old fuel. I think i filled it up early this year around Feb. March.
appreciate any other opinions.
Old Nov 10, 2009 | 04:27 PM
MMH2009's Avatar
MMH2009
Start driving your car man. Thats why we have cars
Old Nov 10, 2009 | 06:20 PM
scrapmaster's Avatar
scrapmaster
Do you still have the flap valve hooked up for the heat riser? the valve that is on the passenger side exhaust manifold. When the rod falls off the valve clatters..
Old Nov 10, 2009 | 06:26 PM
wtbrs123's Avatar
wtbrs123
No I have headers installed.
Old Nov 10, 2009 | 06:29 PM
Duane4238's Avatar
Duane4238
Do what my grandfather use to do. If the engine is running OK with no miss and just the noise, take out your hearing aids when you drive it. (hey, I just couldn't resist).
More than likely it's your heat riser. They rust and fall apart and the flapper valve inside the pipe starts "flappin'" and makes a lot of noise. Do what I did and pull the valve off and take out the shaft and butterfly flapper thing and reinstall. Problem solved.
Old Nov 10, 2009 | 06:32 PM
wtbrs123's Avatar
wtbrs123
I have headers install no heat riser
Old Nov 10, 2009 | 06:48 PM
Duane4238's Avatar
Duane4238
Sorry I didn't see the header thing in time. But, you could have a collapsed lifter if your car hasn't been started in a few months. After sitting, the oil in the lifters can bleed off and at start up, they pump right back up. You may have one that isn't pumping up. It happened to me in the spring of '77 when I took my '72 out of storage. Sounded terrible. I thought for sure it was a broken rocker arm or pushrod, but after warming up, the noise went away and it hasn't happened since.
Start her up and let it sit and run for a few minutes and see if the noise disappears. Good luck! Hope that's it.
Old Nov 10, 2009 | 08:09 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I tried ignoring that noise for too long. Ended up finding two bad lifters and a ruined camshaft during the rebuild.
Old Nov 10, 2009 | 09:02 PM
wtbrs123's Avatar
wtbrs123
How do you tell if I have any bad lifters?
Old Nov 10, 2009 | 09:05 PM
bobs77vet's Avatar
bobs77vet
mostly we describe header leaks as ticking noise......possibly recheck all the header bolts.....also you could isolate several systems by diconnecting the fan belts and see if the noise goes away....i would not run the car long like this but a moment or two i dont think would hurt anything on a cold engine. also you could pull the spark plugs and pull the power feed to the distributor and crank the engine and see what you hear.....it may point you to a particular cylinder
Old Nov 10, 2009 | 09:07 PM
wtbrs123's Avatar
wtbrs123
I tried that the other day I ran it for a little while about 10 minites or so but I was concerend about causeing more damage to the engine.
bobs77vet's Avatar
bobs77vet
well you could get a set of old valve covers and cut the top out and watch the valves open and close when the car is running and that would definitely tell you if its a valve train issue. dont try this unless you put a valve cover on it or the oil will get everywhere
Old Nov 10, 2009 | 09:29 PM
wtbrs123's Avatar
wtbrs123
I'll check all that you are suggesting, I will let you how it turn out.
Old Nov 11, 2009 | 06:49 PM
wtbrs123's Avatar
wtbrs123
Checked header bolts found front two on passenger side of engine were loose. I will clean the covers install new gaskets and button her up tomorrow and give her a run. I feel confident that your suggestion was right on.
Thanks Bob.
wtbrs123
Old Nov 11, 2009 | 07:05 PM
bobs77vet's Avatar
bobs77vet
good job let us know how it sounds
Old Nov 14, 2009 | 12:09 PM
wtbrs123's Avatar
wtbrs123
[QUOTE=bobs77vet;1572118592]good job let us know how it sounds[/QU
tighten hesder bolts installed covers cranked engine noise still there let idle while I checked cover gaskets noise stopped, went on a good coutrty drive 50 miles or so return no noise.
cranked it up this morning noise there warmed it up and did a fast idle for a couple of minutes noise gone.
I think it might be what someone suggested a lifter bleeding off.
wtbrs123
To engine noise
