I am cleaning up the engine bay on my 76, as many of you all know from my previous posts, and came up with some more question.
1. I bought timing chain kit from Zip and installed it. I believe I have everything lined up right but when I put the gears on with the chain it was still loose. I have done one on a van before and it was extremely tight so before I try to start it up I wanted to know if it is typically to have it semi loose like this? It is straight from the Zip kit so there shouldn't be any problem but I still wanted to ask.
2. I want a new intake manifold for my 76's 350. The car is going to be a everyday driver, not a dragster. I want to get an Edelbrock that can fit a 650 carb on top. Any suggestions.
3. I will probably find out what this wire goes to once I have everything in place; but right now I just can't remember where it goes. Does anyone have a guess?
That wire looks similar to one I have running from the passenger side underneath the engine to the drivers side firewall of my 76. It ends/clips into another 2 wire clip underneath the brake booster unit. Mine connects to the alternator wire on 1 side of the clip and the other is power for the fuse block if I'm not mistaken.
That is the only heavy guage red wire that splits into a double clip I can see.
If you want to upgrade the intake try an Edelbrock Performer. It'll clear the stock hood using the stock air cleaner setup.
A brand new timing chain should be snug. Did you replace the gears too or just the chain? I would replace both, no good reason to use used gears. Good quality SBC timing sets are available at any auto parts store for less than $30 last I looked at them.
