Steering Column Assembly Retainer
Old Nov 10, 2009 | 06:31 PM
C3 Craze's Avatar
C3 Craze
3rd Gear
Default Steering Column Assembly Retainer
I had to get to the cancelling cam on my 79. Im putting it back together but have run into an issue. The way I took the retainer for the shaft out doesnt work for putting it back in. Is there a way to depress that spring enough to install the retainer that someone knows? There must be an easier way than Im trying. Its driving me nuts!
Old Nov 10, 2009 | 07:33 PM
08vycpe's Avatar
08vycpe
If you are referring to the steering column shaft lock retainer, you can rent a spring compressor tool from Autozone for free.
Make sure you install it in the correct orientation. See Jim Shea's paper about this.
Old Nov 10, 2009 | 07:34 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Have someone push the locking plate in while you slip the retainer in...It can be done.Or use the tool.
Old Nov 10, 2009 | 09:47 PM
Jim Shea's Avatar
Jim Shea
You need to lock the upper shaft from sliding when you use the locking plate compresser tool. You will need to first install the star screw and lock the upper shaft. If the star screw interferes with the compresser tool you will need to use a 5/16-18 UNC set screw or a #20 allen screw to lock the upper shaft.
Then the tool will work correctly.
Jim
Old Nov 11, 2009 | 12:23 AM
C3 Craze's Avatar
C3 Craze
3rd Gear
That is the issue I had with the shaft. And so locking it will hopefully do the trick. Thanks guys! Just another issue with my C3...
Old Nov 12, 2009 | 01:13 AM
C3 Craze's Avatar
C3 Craze
3rd Gear
Well it worked. Though I was so ready to get it together I used a predrilled driveshaft loop bracket and 2 bolts and nuts and it went down perfect. haha thanks guys!
Old Nov 17, 2009 | 02:44 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
jim shea is da man!!!
To Steering Column Assembly Retainer
