AirGap Vacuum port for headlights?
Old Nov 10, 2009 | 07:15 PM
ImBatman's Avatar
ImBatman
Default AirGap Vacuum port for headlights?
Hey where do you guys with Edelbrock AirGap intakes install your plug for vacuum to operate the headlights? I have a BB so if any of you have a pic that would be great!
Wade
Old Nov 10, 2009 | 07:44 PM
gingerbreadman1977's Avatar
gingerbreadman1977
a TEE at the back. mines a 3 way . 1 port to lights, 1 port to pcv and the other i have bunged off..... although i was fiddling with vacum lines myself when this picture was taken so it may not look like how i described in the picture but you can still see the lights vacum line shooting off to the left.
Old Nov 10, 2009 | 07:52 PM
ImBatman's Avatar
ImBatman
So you are porting your pcv into the manifold and not the back of the carb??? I don't have a wiper door so I just need the port for the lights and if it is a better option I will port the pcv to the intake.
Wade
Old Nov 10, 2009 | 08:13 PM
gingerbreadman1977
thats correct blackrat , i sent my brakes to the one on the back of the carb.
Old Nov 10, 2009 | 08:23 PM
ImBatman's Avatar
ImBatman
Cool thanks for the info! I am running a hydroboost setup so I don't have the vacuum line for the power booster.
Wade
Old Nov 10, 2009 | 08:46 PM
gingerbreadman1977
sweet as. you can go either way then but you might as well make use of that carb vacum . i believe its the most vacum so it should speed up your pop up time if you go there.
Old Nov 10, 2009 | 10:55 PM
DRIVESHAFT's Avatar
DRIVESHAFT
You should never run your PCV line to a vacuum port on an intake runner.
You will make that cylinder run way lean.
Old Nov 11, 2009 | 12:19 AM
gingerbreadman1977
now you tell me driveshaft. mine has been hooked up like that for a year.
but thanks man you might have saved me from bang rattle rattle bang.
so should pcv go to carb and brakes/lights to manifold?
ill pm black rat incase he doesnt read the bum steer i put him on.
Old Nov 11, 2009 | 10:03 AM
ja1724's Avatar
ja1724
St. Jude Donor '12
I always put the PCV on the carb port and the brakes & lights on manifold vacuum.
To AirGap Vacuum port for headlights?
