Headlight housings stuck in up position
Old Nov 12, 2009 | 07:04 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
Default Headlight housings stuck in up position
Had to do the third option to get my headlights up this morning at 0-dark-thirty.
Removed vacuum hoses from back of actuator, liften housings by hand.
I know I'm not supposed to get them to go back down by hand, but...how do I get them back down?
Or is it necessary to take the housings all the way out?
Old Nov 12, 2009 | 07:14 PM
...Roger...'s Avatar
...Roger...
Pull down on the center of the mechanism and it will break in the middle and release.
Old Nov 12, 2009 | 07:23 PM
Gordonm's Avatar
Gordonm
Won't hurt a thing going up and down by hand. You do not have to take off the vacuum lines either. As said above grab the "knee" of the joint and pull it and the housing will start to go down. It might go all the way down by itself or require a little help.
Old Nov 12, 2009 | 08:25 PM
DVNTST8's Avatar
DVNTST8
St. Jude Donor '09
Thank you, gentlemen.
To Headlight housings stuck in up position
