Radiator core support
Old Nov 17, 2009 | 03:03 PM
Classic75's Avatar
Classic75
Default Radiator core support
On my 75' right underneath the radiator there is a bar that goes across the car, under the radiator, that looks to be just bolted to two angle brackets and then connected in the center with a long screw support of some kind. I know it's part of the core support, but it looks like this support bar could just be unbolted and replaced, but all I can find for sale is the entire core support structure. Am I missing something here?
Old Nov 17, 2009 | 03:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post a pic. I'm not sure what you're looking at. Have you checked the AIM for the bar?
Old Nov 17, 2009 | 04:50 PM
MelWff's Avatar
MelWff
unless the 75 is different, the radiator core support is one piece. On the bottom are 2 bolts to the crossmember and a single long bolt towards the nose. Plus the other bolts on each side.
Old Nov 17, 2009 | 06:13 PM
Classic75's Avatar
Classic75
Old Nov 17, 2009 | 08:29 PM
'75's Avatar
'75
That is the core support, it's one piece. Be sure to order all the foam seals that seal around and above the radiator too.
Old Nov 17, 2009 | 08:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Classic.. Everyone is correct, the lower section for this support is not available separate. I do have the core support in the forum special price section. You an view it at this link:
Radiator Support. 73-76E 279.00
http://willcoxcorvette.com/product_i...ducts_id=26805
Willcox Inc.
To Radiator core support
