I am thinking of upgrading my brakes on a 1980 vette. The brakes work well but just don't seem to be that good. What upgrades have you done to your brake system for decreased stopping distance? I was thinking of bigger rotors and calipers but wonder if that would just lock up the tires. What would be even better (IMO) is being able to do a swap from the junkyard for newer brakes if that is possible. I rather do that than spend 1-2k for a brake setup. However, if the cost/safety does not improve the braking enough the kits may be worth it. I am on a budget which is why I am thinking junkyard setups. Also, if I go bigger I know I will need bigger wheels which are also an upgrade I am working on. Just have to figure out how wide and tall I want to go for best performance.
The brakes on my '77 are more than good enough for street use. They are well balanced and stop dead straight. If your car has not had the brakes serviced recently there is a possibility that some thing is not quite right. This is a common occurance on these cars. Give us some more detail about your car like, Have the calipers been sleeved with stainless steel bores, any fluid leaking from seals on calipers or master cylinder, pad and rotor condition, any pulling under hard braking? mds...
I have a hydroboost on mine with stock everything else. For street use you do not need anything else. All the rest is just show. I autoX my car and have never run out of brakes. Now a track car yes you should do an upgrade. You can only stop as fast as your tires will allow also.
Whats your suggestions for brakes?
You have 16 brake pistons with the C3 brakes. You will not find a similar setup at a junkyard unless they have a lot of late model high-$ exotic cars available (not seen in my experience). You would also have to engineer/fabricate all of the mounts and figure out the master cylinder. If you have stainless-steel sleeved calipers, rebuild them with a VB&P (or other vendor) O-ring kit and they should work great. Cost will be < $170.00 for the rebuild kit. If your brakes don't have the SS liners exchange them for ones that do at Autozone or Advance and when they start leaking buy the O-ring kit.
There really is no limit on what you can spend these days on brakes. Look at the brakes on a new ZR1 as an example. Also keep in mind big brakes - big rotors - big wheels and tires. Where do you stop (literally speaking )? It's real easy to get carried away especially after you look at all these high end brake kits on the pro-touring cars. You need to be honest with yourself and base your descision on how you are going to use your car and your budget. As "Gordonm" suggested if you need to upgrade beyond getting the stock set up to optimum performance the hydroboost should be more than enough.
Stock brakes with good pads are good enough for non racing. Your front tires are what really make the difference. Hawk or some of the carbon metallic
totally pump new higher temp fluid through
Get some Hawk street compound brake pads and make sure your calipers are in good working condition. Also make sure the rotors are installed correctly and don't have too much runout (not sure the exact value off the top of my head but any shop manual should be able to tell you).
For a street car, you do not need larger brakes. I've managed to pull 1g using stock size rotors & calipers, with a good brake pad compound. C3 brakes are very good if working properly. They only need upgrading for track use.
I would spend the extra cash in getting the best tires you can find. That's where the improvement will be.
WOW awesome information... way more than I could ever ask for! Thank you.
My use of the car is street and if I can take it to a track I will just because its fun. I always was told if you build the car to be faster you need to do the brakes so you can stop too.
I will have to give my car a good inspection on the brakes. I am picking it up friday if everything goes to right. I drove the car and it braked ok but I think it could be better or I am just use to modern brakes.
From what I gather I should just save my money. Maybe change out the brake pad compound plus cross slotted or drilled rotors would help to for heavy braking. I did read another good article on the hydroboost and will have to check into that.
Or you can go with the Wilwood D8's and not have to worry about pumpin air into the brakes and leaking lip seals. The pistons are SS with an open end design and it reduces heat transfer. They are a direct bolt on and weigh approx 5 lbs vs stock which is approx 11 lbs. You can use stock corvette brake pads as well.
Slots and holes decrease the area of the friction surface- no 'braking' occurs in the area where a pad is over a hole or slot. This is obvious.
The supposed benefit is the holes and slots allows 'gas' created by the pads to vent as they wear away, permitting the pads to come in closer contact with the rotor surface.
In reality, pads produce little or no 'gas' during street operation. Many manufacturers of slotted and drilled rotors state that their products should not be used for racing applications due to concerns over stress cracks.
Save your money.
Thank you for explaining. Race cars may use something like that but they have the money to buy new ones all the time.... unlike me
