Oil Filter question..Need info ASAP????
Old Feb 27, 2002 | 09:00 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Oil Filter question..Need info ASAP????
Well changed the oil in my 79 Vette today..Removed the AC delco PF25 and installed a Mobil 1 M1-302 a larger finer filter for better filtering...But now am not sure of the application..I was under the impression that the m1-302 replaced the pf25 and that they were the same filter except the M1-302 was longer for truck applications...Anyone familiar with the mobile 1 filters....Can tell me If I have the correct filter on the car..Thanks in advance
Old Feb 27, 2002 | 09:24 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Oil Filter question..Need info ASAP???? (BADCAIMAN)
You asked two days too late. I just threw away the box from my filter the other day and the vette isn't close right now. That sounds right, but I can't remember if it was the 302 or the 301. Have you checked the local parts store? They have books that will say what engines the filters fit.
Old Feb 27, 2002 | 11:03 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Re: Oil Filter question..Need info ASAP???? (sharklover)
I have called 4 local auto parts store and all they can give me is the direct replacement for a 79 corvette...I know the Mobile1 M1-302 is not a direct replacement for the AC/DELCO PH25...But I believe it is the same filter except for the fact that the M1-302 is longer....Otherwise not sure if it has a check valve to stop drain back...Can anyone help..Thanks
Old Feb 28, 2002 | 06:49 PM
BADCAIMAN's Avatar
BADCAIMAN
TTT Anyone :jester :jester :jester :jester :jester :jester :jester
Old Feb 28, 2002 | 06:59 PM
Rocketman50's Avatar
Rocketman50
Try this site...it has a catalog that says M1-202.
http://www.exxonmobil.com/netcom/mob...re/index2.html
Old Feb 28, 2002 | 10:57 PM
Ben Taylor's Avatar
Ben Taylor
I've been using that filter for about 6 months now (not the same one) and I haven't noticed any problems, I've always ran the larger filters and I haven't had any problems because of it.
Old Feb 28, 2002 | 11:05 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Re: Oil Filter question..Need info ASAP???? (Ben Taylor)
Ben.... Are you running the M1-302 in your vette????...No problems..leaks and such????...Thanks
Old Feb 28, 2002 | 11:33 PM
Ben Taylor's Avatar
Ben Taylor
It's on my 81 vette, and I haven't had any leaks yet. If you look at the top of the MI-302 it's exactly the same as the M1-202, the only difference is it's longer, the threads are the same size and pitch, the seal is the same size.
[Modified by Ben Taylor, 8:37 PM 2/28/2002]
To Oil Filter question..Need info ASAP????
