Big Block Cylinder Head Advice Needed
Old Nov 21, 2009 | 09:45 AM
jon68l79's Avatar
jon68l79
Supporting Lifetime Member
Default Big Block Cylinder Head Advice Needed
I know there are a ton of threads with this similar question, but everyone's situation is a little different, so...need some advice on my engine build. It's a street (not raced) car.
I've got a rebuilt .060 over 454 short block with domed pistons (cr should be about 10:1 with stock 781 heads). I'm planning on upgrading the cam to a solid roller, but haven't picked which one yet.
I also have a set of rebuilt '781' cast heads (marked 'X' - what does that mean?). They are oval-port. I know I'll have to upgrade the springs for the roller cam if I stick with these heads.
I'm considering going with AFR 305's or 315 intake volume aluminum heads (rectangular port). My question is - is that the right head for my street car? Should I be looking at larger volume heads (>325)? AFR's website seems to point to these as a great street/torque monster. I have always heard that you should stick to oval-ports unless racing, but all AFR's are rectangular I think.
Am I wasting my money going with the AFR's verses just using what I have?
Any other recommendations or advice? Thanks!
Old Nov 21, 2009 | 10:02 AM
67tripwr's Avatar
67tripwr
Oval port big Chevy heads are great for the street! You can do some port matching, polishing of bowl, install larger valves etc.... For the street, I really don't consider rec port heads necessary. If you really want to go up in rpm, and shave some weight I would go with rec port aluminum heads.
Not sure about the "x" on the heads
Old Nov 21, 2009 | 08:56 PM
Little Mouse's Avatar
Little Mouse
AFR has a 265 runner oval port head. if i had your 467 engine running a milder solid roller the 305 or the more CNCd 315 AFR would be exactly the head I would be most likely to buy.
Old Nov 21, 2009 | 09:41 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMCO, there's little reason to go with a solid roller unless you're planning to rev it up, in which case you ought to go with some respectable flowing rectangle port heads. But, since it will be on the street, I'd be careful not to go overboard on the cam/head combo and end up killing port velocities. The less time you spend with WOT or near the redline, the larger is this concern. Keep in mind that the better the heads flow, the less cam will be required to do the same job, and vice versa. And, it should go without saying that the optimum CR will depend much on that cam choice. The ~75# weight savings from going with aluminum BB heads is well worth having. And, if exhaust port location means anything to you, don't overlook that detail. Hope that info is more helpful than confusing.
FWIW, I'm in the middle (bogged down due to budgetary constrants) of a pump gas, alum head, solid roller, 427 BB build up myself, so I've given this stuff a bit of thought.
Old Nov 21, 2009 | 10:10 PM
Grumpy 427's Avatar
Grumpy 427
I had the 305's on my 468, and they were too big for a street motor. Nothing under 5000 rpm. I spoke to Dart, and they have a killer set of oval port heads that would of been better for a 468. I had 12.0-1 compression and a .691/.684 lift .262/.272 @.050 solid roller. Call around, and go with oval ports you wont be sorry.
Old Nov 21, 2009 | 10:13 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
You can't go wrong with AFR, just tell Tony what you are going to do and he will set you up. I bet he will tell you to go with the new oval port head. If you were racing or above 5000 rpm alot it would be the 305 with the cnc option. Or if you want a turn key engine at a great price call a company called Vortec Pro, 1-719-650-1609. Mike does outstanding work and is talked about at the team chevelle site alot. If I could sell my 460 BBC with the 990 Gm rect ports, I'd use him without a doubt. Ron B.
Old Nov 21, 2009 | 11:14 PM
ajrothm's Avatar
ajrothm
+10000000
I just got my 657hp pump gas, 049 ovals, hyd roller 496" from Vortecpro.....I will never buy an engine from anyone else.... Mine made within 4hp between two different dynos, 1500 miles away and 6300' difference in altitude...Best $8k you will spend on a motor....
Old Nov 21, 2009 | 11:15 PM
tt 383's Avatar
tt 383
Just something to think about if money is a concern, reworked iron will leave money for a hyd roller upgrade or cover most of it. If you have an oval intake thats more money to spend to go rect. For the street and the smallish cubes its probably the easiest and most cost effective way to go. The good ovals 049/781 heads can support over 500hp. If money is not a problem or you even think you will be doing something bigger in the future like a 509/540/565 than definately get the AFR's.
Old Nov 22, 2009 | 12:27 AM
eagle275's Avatar
eagle275
Are the 3872702 427 Oval Port Cylinder Heads any good?
Old Nov 22, 2009 | 09:46 AM
jon68l79's Avatar
jon68l79
That's good to know. I'm not looking for a high rpm motor, but rather something with good low end and driveability. Do you happen to remember the which Dart heads they recommended?
Yes, money is always an object. But at the same time, spending a little money to go the wrong direction is worse than spending more money to the right way the first time. Sounds like I need to call around to a few manufacturers.
Thanks for all of the great advice? Anyone else have any recommendations for a 468?
Old Nov 22, 2009 | 10:02 AM
jon68l79's Avatar
jon68l79
Can you explain what this means? I see that some heads have a raised exhaust port, but I never paid attention to it. Does that affect how the manifold/header connects? I was planning to go with McJacks tubular manifolds that bolt up to the stock location of my side pipes. Will that be a problem?
Old Nov 22, 2009 | 07:00 PM
TheSkunkWorks
Yes, port location can cause fitment issues, depending on where they are and what you're connecting to them. Just making you aware before you learned on your own to watch for this potential problem.
Old Nov 22, 2009 | 07:18 PM
Grumpy 427's Avatar
Grumpy 427
The nice thing with the oval port head, is they have a smaller runner which offers great air speed and more velocity. But they can be reworked to pull strong to 7000 plus RPM without killing your bottom end. I am not sure Which head it was that Dart had? You would have to call them up and ask them. Tell them your combo and your goal for the car and they will help you out i am sure.
Old Nov 22, 2009 | 07:31 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The 781 heads that you already have are really good street heads.
Have the rect port sized valves (2.19"i, 1.88"e) installed along with a bit of bowl port work done and they are even better.
If you have your heart set on aluminum heads, take a look at the Brodix oval port Race-Rites in addition to the Darts & the AFRs.
While all 3 make good performing heads, only the Race-Rites have the exhaust ports in the stock location.
To Big Block Cylinder Head Advice Needed
