ZZ454 Increasing compression ratio question
Old Nov 21, 2009 | 04:32 PM
10caipirinhas's Avatar
10caipirinhas
Default ZZ454 Increasing compression ratio question
When it is slow at work, you get to thinking........did some calculations and you've got to remove .035 from somewhere, to get it up to 10.5-1 from the stock 9.6-1 compression ratio without swapping pistons or heads.
So the question becomes.....
1) Is there a thinner head gasket with a lower compressed height that would be just as durable as the thicker stock part, that can be used to accomplish some of that .035 reduction ?
2) Or would you just mill the head .035 accordingly assuming there is enough meat to do so ? And there should be plenty.
All of this is on the assumption that the stock dished pistons would have plently of valve clearance with the stock, or even a mildy upgraded HR cam.....and as I think they easily would clear, since you've got it apart to do this, you just clay it up anyways to be safe.
With the 110 cc heads having 10.5-1 it will give you more HP with a better cam and you'd still be pump gas friendly with this simple mod. We've got 94 octane up here which I don't wanna waste on lower compression if I do this.......
Thoughts ?
Old Nov 21, 2009 | 05:15 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Whack the heads. Edelbrock makes those aluminum heads and sell a 100cc version of them.
Then use a .015 Cometic gasket.
Then put a decent cam in it and have some fun!
JIM
Old Nov 21, 2009 | 07:57 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
-.035 off the heads yield different cc reduction than -.035 off the block and gasket. With Jim. Take as much as you can with the gasket and mill the rest out of the heads. Watch the Cometic. You need a super smooth surface for them but they are really good gaskets and available in custom bore and thickness.
Old Nov 21, 2009 | 10:01 PM
midyearvette's Avatar
midyearvette
i would think if you boosted the cr with the stock roller zz cam you would get pre ignition unless you killed back your total advance..9.5 -1 is about max with a 211 dur. @ 50 off....at 10-1 you would need 220 min. at 50 off...remember the 454ho was around 8.5 with the same stick..jmo...
Old Nov 21, 2009 | 10:41 PM
10caipirinhas
Thanks for the replies everyone. Amazing board.
Stock compressed gasket thickness is .040 IIRC so with the suggested Cometic gasket I'd only have to take .010 off the heads, which should be a no brainer.........never heard of Cometic, but looks very interesting from what I briefly read on their site.
I want to keep the bigger 110 cc chambers so I can't swap heads for smaller ones, as I need to use these with the higher compression and extra duration, for more power on the gas we've got (94 octane)........and say around a 230 intake and 240 exhaust duration @ .050 cam but with overall lift similar to the stock piece.....subject to valve clearance. There is a name for the particular "effect" that allows this to occur and it escapes me at the moment.
I figure I can get around 525 HP +/- and not have to pay the price.
Old Nov 22, 2009 | 03:49 PM
427Hotrod's Avatar
427Hotrod
Not suggesting to swap heads. The GM performance heads are made by Edelbrock and Edelbrock sells a similar version already milled to 100cc. So what I'm suggesting is that there is a lot of room to mill those heads that you currently have.
Your pistons are likely .020" or so down below the deck at TDC...so that drastically affects final compression. Shoot for .035-.045 TOTAL clearance between the piston and the head including deck height AND gasket. If the block was *zero decked* then the .040" gasket would be fine.
Don't limit yourself on lift. Lift has very little to do with PV clearance because the piston is a long way from the valve when it reaches max lift. Duration, LSA and ICL of the cam determine piston to valve clearance more than anything. I wouldn't put anything less than .600" lift in there. Just double check your springs and retainer clearances etc on the heads.
JIM
Old Nov 26, 2009 | 11:44 AM
10caipirinhas
OK gotcha........thanks for the FU.......
I am not looking to spin over 6,000 and want this thing to make it 50K miles in 5 years of hard DD use before it gets torn down for a refresher.......you think spring pressures, cam/valve train wear, etc, will be OK over that period with .600+ lift or so........?
Old Nov 26, 2009 | 12:02 PM
midyearvette
dont worry, it wont spin over 5400 or so unless you go to the beehive springs anyway...valve float....i think your 230 ish at 50 off is a little strong unless you run a gear...i would stay in the 220 range .....jmo
Old Nov 26, 2009 | 01:51 PM
10caipirinhas
Gonna use a 3.70 or 4.11 rear end with a TKO600 and the appropriate internal ratios.
Don't think you'd get valve float @ <6,000 rpm if using a complete cam kit and any other of the recommended matching pieces to accomodate the design RPM. Here's what I was thinking.
http://www.compcams.com/Cam_Specs/Ca...?csid=584&sb=2
or
http://www.compcams.com/Cam_Specs/Ca...?csid=583&sb=2
Old Nov 26, 2009 | 08:09 PM
Rmorgan&11's Avatar
Rmorgan&11
Read directions on the COMETICS ...they are a " Multi-Layer " style...the ones I have stated to coat EVERY LAYER with a sealant , I used the Red spray Permatex gasket sealant between each layer and allowed the sealant to set before bolting them up ..
Running Aluminium heads & Steel Block
They have held up in my Race Boat for 6yrs now ...454 -8/71 @ 22#boost on 8:75-1 static Compression
prepped correctly ,you should not have any worries about using the Cometics
Old Nov 26, 2009 | 08:43 PM
10caipirinhas
Thank you !!!
Old Nov 26, 2009 | 10:04 PM
63mako's Avatar
63mako
Read the directions.
This is from Cometic's website:
Why does Cometic recommend MLS gaskets to be installed dry?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
So is this:
What surface finish is required to us an MLS head gasket?
A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
50RA is almost a mirror finish. A lot of factory blocks and or heads do not meet this surface finish requirements. A lot of decking and milling equipment will not leave a smooth enough finish. You need both checked and/or resurfaced on modern higher end equipment to use these. If the surfaces are right they are one of the best gaskets available.
Here is some more info. http://www.cometic.com/faq.aspx#q2
Old Nov 27, 2009 | 02:00 AM
badrad's Avatar
badrad
You might want to measure your heads chambers before jumping in. Lots of those are coming in with 114cc+ chambers, plus GM's math tends to suck so ~9.2:1 is usually the true compression. IMO cutting the heads down to 100cc is the way to go but you might have to cut your intake to match the new angle.
Old Nov 27, 2009 | 10:29 AM
Rmorgan&11's Avatar
Rmorgan&11
63 Mako
Thanks for the update on Cometics
I Definately don't want to steer someone in the wrong direction /
I had mine custom ordered and they came with a slip of paper stating to use sealant .
Its been quite awhile since I ordered mine
Old Nov 27, 2009 | 12:32 PM
63mako's Avatar
63mako
63 Mako
If I remember correctly they used to not have the rubber coating.
To ZZ454 Increasing compression ratio question
