Rocker conflict - help needed (pictures)
Old Nov 22, 2009 | 10:55 AM
aremar2's Avatar
aremar2
Default Rocker conflict - help needed (pictures)
Hi. Trying to mount new Scorpion roller rockers that comes in conflict both inside and outside.
* Outside towards the upper head studs. The head studs are not centric between the rocker studs - causes one side of one rocker to conflict.
* Inside towards rocker stud foot.
For the outside conflict I see a solution i changing the four upper head studs with the original bolts, would solve the problem.
For the inside I have no idea????
Is it something I´m missing here? The head in a Brodix IK180, the head bolts are ARP, original pushrods.
Could you please help me out :o
Old Nov 22, 2009 | 11:01 AM
Gordonm's Avatar
Gordonm
Are you sure you have the correct length pushrods?
Old Nov 22, 2009 | 11:15 AM
midyearvette's Avatar
midyearvette
..good catch....did you check for proper geometry??
Old Nov 22, 2009 | 11:18 AM
Chandler's Avatar
Chandler
The push rods look short. Maybe someone with those heads will have a more complete answer.
Is this what your doing during the long nights?
Old Nov 22, 2009 | 11:19 AM
aremar2's Avatar
aremar2
No, not really, didn´t think of it. Maybe I got to measure for the right pushrod length.
Anybody with a simular setup who have experience about the correct length?
Old Nov 22, 2009 | 11:23 AM
aremar2's Avatar
aremar2
Thats right - six months of winter ahead here in Norway, and nothing else to do at nights. So I got plenty of time to figure it out.......
Old Nov 22, 2009 | 11:25 AM
midyearvette
each mill is slightly different and be glad you caught this before you buttoned it up.....go to lunati's web and check it out with great pics..easy to do and if i may recommend comp cams custom length pushrods and btw i really hate your avatar..wtf??......
Old Nov 22, 2009 | 12:30 PM
...Roger...'s Avatar
...Roger...
Dang that gives me chills.
Old Nov 22, 2009 | 12:56 PM
aremar2's Avatar
aremar2
Well, I´m a little bit hurt here, had a big job finding that picture in the family album. Will change it this evening..
Old Nov 22, 2009 | 01:05 PM
aremar2's Avatar
aremar2
Default Thanks
O.k. - see my mistake, the pushrods are far to short. Looked at the lunati side, ordering a check pushrod today. Will also change my avatar as requested......
Old Nov 22, 2009 | 04:54 PM
gkull's Avatar
gkull
With certain setups you have to have longer pushrods, rocker studs and longer valve stem lengths
Old Nov 22, 2009 | 05:17 PM
midyearvette
Old Nov 22, 2009 | 05:21 PM
...Roger...
Don't get rid of it I might want to borrow it and put it on my girlfriends puter as a screen saver.
Old Nov 22, 2009 | 05:47 PM
Gordonm's Avatar
Gordonm
That was a bit disturbing. What kind of freak does stuff like that.
Old Nov 22, 2009 | 07:26 PM
TJP440's Avatar
TJP440
Living here in nebraska with winter rapidly approaching I'm all for Global warming. Scr-w you guys in the warm climates LMAO
Old Nov 24, 2009 | 06:14 PM
aremar2's Avatar
aremar2
O.k. I have ordered a comp cams check pushrod from Summit (and some other stuff...) starting there. Hope the 1.5 rockers will do o.k. - will come back to it if not. Glad my new avatar didn´t give you chills.
To Rocker conflict - help needed (pictures)
