94 LT1 350 thoughts?
Carl
Unless u have an electronics background the FI conversion u will have a very steep learning curve. Its not real complicated but things like logic pulses may really frustrate u if you need to verify or troubleshoot all the sensors/devices.
For the carb conversion all u need is that GMPP dual plane intake and install electric fans for cooling the radiator. U can use your old carb, distributor and set up the ignition just like the original C3.
Be careful here. The LT1's were externally balanced and had a zero balanced dampner on the shaft nose. That means all the external balance was done by the flywheel - flex-plate in your case. Your gonn'a need a one piece shaft flex-plate balanced for an LT1 that has the correct number of starter teeth for your starter/trans position.
FYI the iron head LT1's (5.7L or 4.3L) all used the same cam. It was more of a truck cam made for torque and low rpm. The duration was pretty short at 0.050" with only 191* on intake and 196* on exhaust (but had a tight 111* LSA
). While u will have good low end it will stop breathing before 5000rpm and fall way short of 300hp. I would upgrade the cam for a C3 application but maybe u can find a good used LT1 cam for cheap. Don't worry as most stock roller cams that year were made of billet steel and last forever with roller lifters. BTW i still have my old stock cam in my aluminum head '94 LT1 that i will remove soon.
202* intk / 207* exh @ 0.050" with 116* LSA - only 170K miles on it.
Would u like to trade for something? I need another LT1 FI intake for porting with my old heads as the original is still in use on the car.cardo0
Also the LT1 s don't have the key slot for the dampner. The dampner (bracket) is fiction fit only.
Another problem is the turbo 400 has no output signal for his PCM. The PCM controls shift points and will need a response from the trans. It also calculates vehicle speed from the trans vehicle speed sensor. I don't know how u can bypass or "dummy" those PCM inputs. Maybe marktn can explain how he did it.
cardo0
cardo0
You can buy a VSS generator from many sources; Howell, Street and Performance, Painless, etc. It screws inline with the speedometer cable where it screws to the transmission. Use manual transmission PCM programming and all you need is a VSS input. I would personally use the 4L60E from the donor car, but a TH400 is not hard to set up the computer for. Same friend with now Turbo LT1 Camaro has a TH400 in it.
By the way. Why are we
? I am trying to give facts and not personal attacks.
Ok then read this : Rebuilding the Chevrolet LT1 Engine: By Doug Anderson @ http://www.enginebuildermag.com/Arti...t1_engine.aspxCRANK KEYS
There is no keyway in the hub for the harmonic balancer, so GM used a special cutback key that was flush with the front of the timing gear on the 1992-’95 engines. It’s p/n 10128303.
When the crank position sensor was added in 1996 for OBD II, the cutback area on the key was shortened so it stuck out far enough (about 0.100") beyond the face of the timing gear to index the notched disc that was used for the crank position sensor.
No personal attacks implied and i do like what u say about the VSS generator.
But w/o it read like u were leading the way to a dead end here. And what i can't seem to get through is that the LT1 crnk balance is different from other one piece seal crnks (externaly balanced).
cardo0
I can see my advice/information is not understood nor appreciated here. So good luck to u and your LT1 conversion.
cardo0
http://www.mortec.com/cranks.htm
GM Performance also seems to confirm this.
https://store.gmperformanceparts.com/store/SelectProd.do?prodId=7896&redir=true&man ufacturer=GM&category=Cylinder%20Block%2 0&%20Components&name="Crankshaft,%20Cast %20Iron"&model=<!--14088526-->
According to another site I found, all 1-piece seal 350s are internally balanced with the right damper and flexplate/flywheel. If you look at the F-body go-fast pages, a very common mod on an LT1 is to key the crank hub. Even though it is not keyed, it is put in at a specific place. For example:
http://www.golenengineservice.com/ht...ml#crankhubmod
As far as I know all 1-piece seal 350s can use the same flexplate.
http://www.enginebuildermag.com/Arti...balancing.aspx
Jegs lists no differences in flexplates for LT1 and standard 1-pc seal applications.
GM Performance Parts, same thing.
https://store.gmperformanceparts.com...umber=14088761
Finally, see this page on LT1 with TH400 swap.
http://www.ls1tech.com/forums/automa...questions.html
