383 cam break in.
350 4 bolt main, .030 over bore, Eagle Crank and Rods, Speed pro -12 dish pistons, deck planed to accomplish 10:1 C/R, H/V Oil Pump, 7 QT base pan, Edelbrock 200cc Vortec Heads, Edelbrock RPM Air Gap Intake, Aluminum Roller Tip Rockers, 770 Holly.
We used the old valve covers from the old 350, [I]a little sandblastind, polishing and painting[I].
I am already aware this set up won't fit under my stock hood but that is only one more issue that has to be dealt with on this build.
The motor stand set up didn't quite work out, rad too far from the fan, she started to run a little warm.
Thanks for your time
C
Thanks for the input.
C
The rings should be seated using the proper procedure as soon as the motor is ready. For a roller cam motor that is 5 mins to warm up and check for leaks for a flat tappet it is 20 minutes then take it out an let it rip to seat the rings otherwise you could have oil control problems in the future if you are starting it up and running for long periods for time on an engine stand with no load on it.
Even on my brothers old 318 Chrysler engine I used the same practice, it's just not worth wiping a cam out for the sake of 20 minutes.
I had my brand new 427ci motor up to 5000 RPM on the street 5 minutes after I had it running. If it wasn't built properly it's going to fail the first 5 minutes or 2 months down the road. Mine runs like a clock a year later with 10k on it. Drag racers don't baby their motors for 500 miles, 1/4 mile at a time
They break in the cam and then make a full power pass
Have done the same for many a motor. Mine saw 6500 rpm in the first 5 miles after break in. I have been driving it hard ever since with no problems. If it was machined and built properly it will last.
The way you describe is fine. I put it in second or third and punch it to about 4500-5000 rpm and then let my foot off and let the engine slow it down. Doing this forces the rings into the walls a different way than under acceleration. Been a while since I read the exact theory behind it but I do this 3 or 4 times and I have never had an oil burner. As a matter of fact I never even check the oil, I just change it in the spring and fall.
C
All of the older information on Ring break in comes from the days of Cast Iron rings, common up till 1982 or so in most factory engines. Cast iron rings are now gone except for some second rings, the scraper ring. Your compression is held by the top ring and those are all moly now. Some of the newest engines are testing or running more exotic compounds than moly. New car standards are pushing manufacturers to produce ring packs that offer up to 20,000 miles per quart of oil consumption to reduce emmisions and to maintain these standards for more than 100,000 miles. The old days of burning oil are pretty much gone. You have all enjoyed the results of this upgrade in your passenger cars that now run 250,000 miles and burn no oil. ( I know fuel injection has helped a lot to this end ).
Cast rings, the old standard, wore much faster and broke in much harder.
We have done alot of leak downs on freashly rebuilt engines to find up to 40% leak down and some engines were up around 5000 Miles on them and one of the biggest complaints was dirty oil in less then 10 miles.
